Home › Forums › General Trade Forum › New way to replace Bosch brushes.
- This topic has 124 replies, 34 voices, and was last updated 16 years, 9 months ago by
leavemetogetonwithit.
June 19, 2009 at 10:01 pm #46495
ParticipantCouldn’t resist posting this. I was looking for some help on the web to fix a DVD recorder that I found dumped next to my dustbin and I got sidetracked as you do, into reading the advice on other sites about how to repair washers. So have a read of this
http://www.fixya.com/support/t969692-re … ssixx_1000
and let us know if this is how you do it. 😆
Mike.June 19, 2009 at 10:37 pm #289646DAR01
ParticipantRe: New way to replace Bosch brushes.
Well there are people out there who would follow these instructions and regret it afterwards.
I would never do it that way,normally remove back plate and access the motor that way, with the machine still upright.
Anyway advice like that given is probably going to give us some more work putting the machine back together again.(Refiting the drum support springs,and what about any debris in the sump hose that falls back into the drum)?
Most of the Bosch machine’s that iv’e worked on don’t require any screws to be removed,(other than the mounting bolts) the brushes simply slot into the existing holders.
Mike
June 20, 2009 at 7:14 am #289647Phidom
No, I’ve never done that with a washing machine but I have a few times with dishwashers. I didn’t like doing it and I’ve given up repairing dishwashers since then. On most machines I remove the motor to change the brushes. I must admit it is a pain on the plastic tub Bosch machines as you can’t use an electric screwdriver and you cut your hands to ribbons on the razor sharp edges of the too-small back panel opening.
June 20, 2009 at 7:58 am #289648Martin
leavemetogetonwithit wrote:and let us know if this is how you do it. 😆
This is how Penguin45 does it.:wink:
This is how Joe Public does it. 😆
June 20, 2009 at 9:23 am #289649aqualectric
Bish bash Bosch………. 😉
Did you hear the subliminal messaging on Chris’ video? “THIS TUTORIAL DOESN’T APPLY TO BOSCH MACHINES AROUND THE LEEDS AREA……….” :penguins:
Steve.
June 20, 2009 at 9:29 am #289650leavemetogetonwithit
Martin wrote:This is how Penguin45 does it.:wink:
😆 I dunno, these amateurs :rolls: . No mention of turning the power off ❗ 😆 .
BTW, who’s that revving up the Austin in the background? 😆
Mike.June 20, 2009 at 9:40 am #289651Martin
leavemetogetonwithit wrote:BTW, who’s that revving up the Austin in the background? 😆
It’s Mrs P revving up the getaway Wolseley. 😀
June 20, 2009 at 9:53 am #289652leavemetogetonwithit
I dunno, these drivers who operate camcorders while driving 😯 .
Better watch out.
Mike.
Edit: Oh, didn’t realise that was a link to a video! Was thinking Mrs P was keeping the engine warm whilst filming Mr P doing the brush change. 😆June 20, 2009 at 10:38 am #289653turbodry
Watching Penguin45’s youtube tutorial is like watching a tree surgeon cutting through the branch that his ladder is propped against!! …. Durrrrr
June 20, 2009 at 12:38 pm #289654robbra
turbodry wrote:Watching Penguin45’s youtube tutorial is like watching a tree surgeon cutting through the branch that his ladder is propped against!! …. Durrrrr
Mrs P will KILL you 😉
June 20, 2009 at 3:06 pm #289655iadom
ModeratorRe: New way to replace Bosch brushes.
I heard of one chap who actually drills holes in the back of the Bosch machines to get at the motor mounting bolts. 😯 😆
Guess who. 😉
June 20, 2009 at 3:16 pm #289656BSH-MAN
Naughty boy (Joe) didn’t fit a cable tie. The wire may snap as it joins the connector. :rolls:
June 20, 2009 at 3:20 pm #289657Phidom
Will have to try the ratchet spanner. The 1/4″ drive socket and ratchet handle are tight against the cabinet back by the time the 2″ long screws are out.
June 20, 2009 at 3:50 pm #289658iadom
WHY?????
June 20, 2009 at 5:47 pm #289659boselecta
ParticipantNever considered putting the machine on its head, always taken the motor out.
Had a Bosch machine that I was unable to remove from worktop and managed to change them from the front, taking front pannel off and putting my hands around the tub. Was very awkard but worked ok.
