Oven not working..grill ok.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven not working..grill ok.
Viewing 15 posts - 1 through 15 (of 46 total)
  • #91773
    superoptom
    Ignis AKL335/01. Electric Oven not working..no sound of fan..funny plastic smell from oven prior to it stop working. Grill working ok. I’m suspecting oven fan motor gone? Is it easy to change? Access from rear, I think?
    Do I need to change oven fan element too? I installed a new one in 2014.
    Thanks!
    #449202
    Re: Oven not working..grill ok.
    if its only the fan motor the element would still get hot
    could be the selector switch burnt out behind the knob
    superoptom
    Thank you Dave. Will open up before ordering a switch.
    #449204
    superoptom
    Just bought a replacement oven selector switch, swapped it over and still nothing is happening.
    There is current to the oven as the grill selector light comes on.
    Any other suggestions before, i decide to ditch the oven please.
    Thanks!
    #449205
    unfortunately I do not have circuit details for this but most simple ovens have
    1 overheat stat somewhere in case of temp too high
    2 poss clock if it has one as oven wont start unless clock is set and switches can burn out
    3 selector switch but you have changed that
    after that is could be a very long shot that both the fan motor and the element had blown. not had that yet but there is always a first time
    dave
    #449206
    superoptom
    The clock is just an old dial one with a buzzer/ringer. It doesn’t turn oven off like a digital timer.
    The selector switch controls the element, fan and internal oven light. None of these are operational. I put a new bulb in just incase. Also the external oven operation light (like fairy light) is not working.
    It’s as if this part of the oven is not getting any power.
    The grill is ok and external grill operation light is working. Already spent £45 on the switch don’t know whether to buy a new oven?!
    #449207
    at a bit of a loss what to suggest as I have no tech on this
    you could post some good quality pictures and I could have a look
    superoptom
    Hi Dave. Tried reducing photos to 256 kiB but not able to get that low resolution without distorting colours. Any other way I can get photos uploaded?
    #449209
    you can upload them to a site like photobucket and put the links in the reply
    superoptom
    Photo of Oven selector switch (replaced) and stat.
    #449211
    superoptom
    Clock, Grill Function Selector & Stat
    #449212
    superoptom
    Rear of oven,
    #449213
    superoptom
    Rear oven.
    #449214
    The resolution of those photos are shockingly bad. But from what I’ve read so far it seems the fault must lie with the TOC and in the fuzzy picture it is likely to be located close to the oven lamp holder I would think?
    #449215
    superoptom
    Sorry couldn’t upload decent resolution…was up early hours trying to!! Thanks for your advice Martin. I did notice that there was burnt, brown marks near the rear side of the oven lamp holder…but thought a lamp holder will not cause these symptoms!! Now to find this part….the oven selector switch was a right PIA as the part was obsolete.
    (I’ll see if I could replace the photos!!)
