Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Oven not working..grill ok.
- This topic has 45 replies, 4 voices, and was last updated 8 years, 8 months ago by
superoptom.
August 17, 2017 at 10:18 pm #449231
superoptom
ParticipantRe: Oven not working..grill ok.
Thanks. Yes I checked for continuity with a digimeter…the reading remained at 1. I would like to “bridge it” to confirm but was not sure how to do it…thought I might do some damage!!
Is it a case of touching the 2 spade paddles together (obviously holding insulated wires), whilst the power is switched on and see if oven/fan starts to work?
If it is the fuse would there be an underlying reason why it blew?
August 17, 2017 at 11:02 pm #449232electrofix
ModeratorRe: Oven not working..grill ok.
NO !!!!
link wires with power off. the spades link quite easily.
make sure they wont touch anything and there is no children round likely to get hurt
turn on and see if it heats. if yes switch off and order part
could have gone through an overheat ( stat too hot or cooling fan not working) or just old age
August 18, 2017 at 8:23 pm #449233superoptom
Hallelujah! Joined spades together…fan running oven heating up!!!
I will order the part and hopefully won’t blow out quickly again…otherwise, back to the drawing board.
I’m ecstatic…Mrs not happy…she wanted a self cleaning oven!!!
Thank you Dave & Martin…Diamond Geezers!!
August 30, 2017 at 8:35 pm #449234superoptom
Back again!!!! Used oven for the 1st time since changing TOC..Tried cooking some cookies for the kids. Semi cooked at the recommended time.
However on turning off oven the inner fan enclosed by the heating element appears to rattle and clunk (metallic sound as if hitting against something) before coming to a halt.
When switched on no sound heard. Will take off the inner covers and inspect when free. Any ideas on what could be the cause.
Thanks again!
August 30, 2017 at 10:14 pm #449235electrofix
bend the fan a bit will be ok
if it does not seem hot enough get an oven thermometer and check temp
https://shop.ukwhitegoods.co.uk/un1470- … hermometer
if its a bit low then you can either replace the stat or turn it up a bit more
August 31, 2017 at 6:47 am #449236Martin
The fan playing up now explains why the TOC popped. :rolls:
August 31, 2017 at 9:00 pm #449237superoptom
Opened up the casing and the inner fan blade literally dropped of on touching it. The holding nut had worked it’s way loose. Gave it a good clean and reassembled…all good now and temperature ok too!!
So because this fan was not dissapating the heat as intended, the heat remained concentrated in one area, overheating the oven and thus blowing the TOC….am I correct??
Thanks again guys!
August 31, 2017 at 9:05 pm #449238electrofix
very likely
September 21, 2017 at 3:08 pm #449239moore7t4
I’ve read this post as I’ve encountered a similar problem with our Electrolux EOD948 double oven.
Top Oven/Grill is working fine but nothing happening in the main oven.
The element in the main oven burnt out and I’ve replaced that expecting that would resolve the issue but I was wrong.
Could you tell me if there is a TOC on my oven as I can’t see any reference to one in the manual I have.
Many thanks in advance.
September 21, 2017 at 5:57 pm #449240Martin
Yes all ovens have TOCโs. Donโt know exactly where yours is located but usually closely attached to the main oven cavity at the back or above. It is a small component with one wire in and one out. Both wires removed and the TOC should be a closed circuit using a multimeter to test for continuity.
September 22, 2017 at 11:44 am #449241moore7t4
Thank You Martin for you reply.
Guess I’ll have to remove the oven from it’s assembly and hunt down the elusive TOC.
Assuming that this proves to be the issue, would you know the product code to source a replacement?
Thanks Trevor
September 22, 2017 at 12:13 pm #449242Martin
Yes, just give us MAKE, MODEL NO AND SERIAL NO. ๐
September 22, 2017 at 2:29 pm #449243moore7t4
Hi Martin,
I can provide Make & Model but can’t read the serial number ๐
Make: Electrolux
Model: EOD 948Hope this helps.
September 22, 2017 at 2:36 pm #449244Martin
moore7t4 wrote:Make: Electrolux
Almost, you forgot the serial number (or in E/lux speak the full PNC number) ๐
Come back if you need any parts once youโve isolated the power and taken the panels off and reached a diagnosis. ๐
September 22, 2017 at 2:51 pm #449245moore7t4
I’m afraid that will be because I can not read the serial number.
My best I can read is the product number, which is incomplete: 3**97*092
