Oven not working..grill ok.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven not working..grill ok.
Viewing 15 posts - 16 through 30 (of 46 total)
  • #449216
    superoptom
    Re: Oven not working..grill ok.
    Decided to bite the bullet and buy new cooker. Unable to source the part – obsolete- gutted! 🙁
    Whirlpool part number 28248226..if anyone can help.
    #449217
    Why are you trying to source a selector switch when it may not be needed? Have you located that TOC yet?
    #449218
    superoptom
    I was trying to source TOC..already got a new selector switch.
    The TOC is near lamp housing? Or located in there?..its quite charred around that area…is it ok to pull the insulation away?
    I’ve googled to see what one looks like…hoping looking for the right thing!
    #449219
    Often look like this….and very small with one wire in and one out….
    #449220
    you could add pictures as an attachment to a private message to me and I will see if I can add them
    but if they are big you may have to send a few messages
    Martin if the TOC had gone would in not stop the grill working as well ?
    electrofix wrote:Martin if the TOC had gone would in not stop the grill working as well ?
    Good point Dave and I would think it likely it would. Though it would depend on the TOC’s location? Even so there must be one and it needs locating to be sure.
    #449222
    superoptom
    I hope these photos are better. Tried finding the TOC to no avail. Checked thermal fuse for continuity – no reading. Is it worth changing this? Any ideas where I can find the TOC?
    #449223
    superoptom
    Top part of oven.
    #449224
    superoptom
    Bottom of oven/grill department.
    #449225
    superoptom
    Top of oven. Selector switch replaced.
    #449226
    superoptom
    Clock, Grill Selector, Grill Temp controls, Oven Temp controls, Oven Selector.
    And that’s it before I give up!! Thanks .
    #449227
    this looks like a fusible link
    try taking wires off and joining them as a test
    or check it for continuity if you have a multimeter
    superoptom wrote:Tried finding the TOC to no avail. Checked thermal fuse for continuity – no reading. Is it worth changing this? Any ideas where I can find the TOC?
    That IS the “thermal fuse” (aka Thermal Overload Cutout 😉 )
    #449229
    superoptom
    Thanks guys.. Need to source this fuse. Tried looking online no luck. Any help would be massively appreciated.
    G5AP1000 TF167C HEB1 imprinted on the fuse.
    #449230
    did you check it or bridge it out to make sure its the problem
    part number should be 481925228078
    yours is 167 degrees and from what I can see so is this one
