Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Oven not working..grill ok.
- This topic has 45 replies, 4 voices, and was last updated 8 years, 8 months ago by
superoptom.
July 26, 2017 at 8:27 pm #91773
superoptom
ParticipantIgnis AKL335/01. Electric Oven not working..no sound of fan..funny plastic smell from oven prior to it stop working. Grill working ok. I’m suspecting oven fan motor gone? Is it easy to change? Access from rear, I think?
Do I need to change oven fan element too? I installed a new one in 2014.
Thanks!
July 26, 2017 at 10:25 pm #449202electrofix
ModeratorRe: Oven not working..grill ok.
if its only the fan motor the element would still get hot
could be the selector switch burnt out behind the knob
July 27, 2017 at 7:53 am #449203superoptom
ParticipantRe: Oven not working..grill ok.
Thank you Dave. Will open up before ordering a switch.
August 3, 2017 at 6:30 pm #449204superoptom
Just bought a replacement oven selector switch, swapped it over and still nothing is happening.
There is current to the oven as the grill selector light comes on.
Any other suggestions before, i decide to ditch the oven please.
Thanks!
August 3, 2017 at 7:36 pm #449205electrofix
unfortunately I do not have circuit details for this but most simple ovens have
1 overheat stat somewhere in case of temp too high
2 poss clock if it has one as oven wont start unless clock is set and switches can burn out
3 selector switch but you have changed that
after that is could be a very long shot that both the fan motor and the element had blown. not had that yet but there is always a first time
dave
August 3, 2017 at 9:37 pm #449206superoptom
The clock is just an old dial one with a buzzer/ringer. It doesn’t turn oven off like a digital timer.
The selector switch controls the element, fan and internal oven light. None of these are operational. I put a new bulb in just incase. Also the external oven operation light (like fairy light) is not working.
It’s as if this part of the oven is not getting any power.
The grill is ok and external grill operation light is working. Already spent £45 on the switch don’t know whether to buy a new oven?!
August 3, 2017 at 9:42 pm #449207electrofix
at a bit of a loss what to suggest as I have no tech on this
you could post some good quality pictures and I could have a look
August 6, 2017 at 3:48 pm #449208superoptom
Hi Dave. Tried reducing photos to 256 kiB but not able to get that low resolution without distorting colours. Any other way I can get photos uploaded?
August 6, 2017 at 4:15 pm #449209electrofix
you can upload them to a site like photobucket and put the links in the reply
August 6, 2017 at 11:44 pm #449210superoptom
ParticipantAugust 7, 2017 at 12:20 am #449211superoptom
Clock, Grill Function Selector & Stat
August 7, 2017 at 12:30 am #449212superoptom
Rear of oven,
August 7, 2017 at 12:34 am #449213superoptom
Rear oven.
August 7, 2017 at 6:48 am #449214Martin
The resolution of those photos are shockingly bad. But from what I’ve read so far it seems the fault must lie with the TOC and in the fuzzy picture it is likely to be located close to the oven lamp holder I would think?
August 7, 2017 at 9:03 am #449215superoptom
Sorry couldn’t upload decent resolution…was up early hours trying to!! Thanks for your advice Martin. I did notice that there was burnt, brown marks near the rear side of the oven lamp holder…but thought a lamp holder will not cause these symptoms!! Now to find this part….the oven selector switch was a right PIA as the part was obsolete.
(I’ll see if I could replace the photos!!)
