Home › Forums › General Trade Forum › Pattern Heaters: A cautionary tale :(
- This topic has 47 replies, 25 voices, and was last updated 19 years ago by
Martin.
April 10, 2007 at 3:03 pm #209479
ParticipantRe: Pattern Heaters: A cautionary tale 🙁
Goatboy wrote:Any word on this from Electrue yet, Martin? 😕
Early days yet GB 😉
April 20, 2007 at 6:54 pm #209480eastlmark
ModeratorRe: Pattern Heaters: A cautionary tale 🙁
Anyone had any probs with the Crosslee/whiteknight/Phillips tumble drier circular element? Have a machine have fitted 2 to, one Electrue pattern and one qualtex pattern and both earthed out after about 2 minutes.
April 20, 2007 at 8:01 pm #209481Martin
Not fitted one for ages Mark but never had a problem with pattern ones as a rule, must be recent stock then? 😕
With oven elements showing the same symptoms, if you isolate the earth then run them on full whack for a few minutes, it does clear the prob. Reconnect the earth and all is well. Have you tried that course of action I wonder?
April 20, 2007 at 10:22 pm #209482iadom
Only problems I have with the T/D elements you mention is trying to stop them catching on the inner drum, usually try and bend them a little before I fit them.
April 24, 2007 at 11:53 am #209483Goatboy
:bang:
It’s gonna be one of them weeks!
:rolls:
“Hello young Goatboy. Can you fix my kettle please?”
“Errrr, not really. Parts are rarely available and new kettles are too cheap!”
“Oh, please Goatboy, I like this kettle?”
Sigh! “Oh, there actually are some parts available for this model, lemme see what I can do.” 🙂
So, it’s a R.Hobbs kettle that needs a new element. Electrue have a non-gen element for a few quid, and the customer is willing to spend £20 on getting it fixed.
Then the element arrives 👿
ELE7597 – Nothing like the original! Does it fit? Does it balls! Does it fit after an hour of modification? Does it balls! Why didn’t I listen to Martin?
June 8, 2007 at 11:16 am #209484kladave
just a quick note to let you all know, do not i repeat do not fit the connect/electrue pattern element ele9050 this fits the neff/bosch ovens that have the 1/2 moon element.The connections are much prouder than the original so the job can not be done without pulling the oven unit out.I thought i could save a few quid but it ain’t worth the grief 👿
June 9, 2007 at 1:17 pm #209485fasetester
Participanthi martin and guys is that a problum with all non genuin heating elements or just the bosch would you say always go for genuin if possible fasetester
June 17, 2007 at 9:21 am #209486rbartlett
I guess the answer would be for the manufacturers to price their spare at a reasonable rate 😯 . Looking at the genuine heaters why are the Bosch ones 50+{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} dearer than other makes?
It’s pretty obvious that Bosch don’t actually make these parts them selves so who does?
Cheers
Richard
June 18, 2007 at 11:06 am #209487Goatboy
It’s always best to fit genuine elements, but some companies (Merloni) charge too much for them, and I find the high prices make customer’s lean toward new machine then 😕
We’ve just had to use trail and error to see which non-gen stuff (from sereval different suppliers) is quality and which is crap!
November 2, 2007 at 9:38 am #209488walnut
At the end of the day pattern or original these element probably cost about 50p to make.
Sometimes the partern part makers get the design wrong but if the original was any good you wouldn’t be changing it in the first place!November 2, 2007 at 3:48 pm #209489Martin
I’ve just recently had a bit of bother with the Qualtex (Bosch/Neff) Half-moon element for their ovens (ELE2052) burning out (within my 12 month warranty 🙁 ) I’ve only fitted 3 in total 2 of which on this one job! Before that I have always fitted the genuine article (494643) and have had no come-backs on those (so far?).
Have any of you guys had the same bother I wonder?
November 3, 2007 at 12:47 am #209490Madmac
I fit a lot of qualtex fan elements & they certainly seem to have a fairly short life. Depends of course how much customer uses the thing. If it lasts a couple of years im impressed, mind u, some factory fit ones are no better. Also had spate of white k dryer ones throwing trips, must try pulling off earth for a few mins tho, never thought o that 😯
November 3, 2007 at 3:39 pm #209491petalpop
spoke to a bosch/appliance care engineer and he reckons the life of these elements is shortened by customers leaving the door open and it cooling down too quick
any truth in that?????????November 3, 2007 at 7:29 pm #209492Martin
petalpop wrote:spoke to a bosch/appliance care engineer and he reckons the life of these elements is shortened by customers leaving the door open
I for one am certain this is the case. In fact after the 2nd element change I insisted they pay closer attention to the time lapse whilst the oven door is left open with the element still burning? How I wish they had door microswitches on elements these days? :rolls:
November 3, 2007 at 8:42 pm #209493cornflakes
just picking up on this thread
require for bosch oven HBN3550gb/02 top ovem element, it retails from BHS at around £70…now what is the alternative ……… cos your looking £100 pus for a simple element change..??? on a cheap oven anyway
having had a few expereinces with patten bosch-neff half circle elements recently,, will now only by gen.
how’s this for a precaution..my local supplier meggers evey pattern element he now recieves and if there is low reading..he bakes them..
it does do the trick..
but how many suppliers are prepared to buy in gen when the margins are so high on stuff with no country of origin.
graham
Leicestershire -
