Home › Forums › General Trade Forum › Pattern Heaters: A cautionary tale :(
- This topic has 47 replies, 25 voices, and was last updated 19 years ago by
Martin.
March 31, 2007 at 2:31 pm #26274
ParticipantThe temptation to fit cheap ‘pattern’ heaters is such that many (like me :rolls:) can fall foul of the sub-standard so called ‘equivalents’ that many wholesalers provide. 🙁
It is worth pointing out the down-side. For example :- a Bosch element (Genuine part No = 265961) Go on Connect and the genuine is £37 + VAT or the pattern (so called) equivalent ELE9044 is only £18 + VAT. 😀
Unfortunately the pattern (whilst looking every bit the part needed) is far from being a suitable replacement. Fit one and all seems fine, it works, job done! But walk away at your peril because the first time the customer uses the machine, it fills with water and then , the heater pops out dumping all the water, and loads loads more, all over the kitchen floor into the lounge and the hallway, floods everywhere!!!!! 😯 😯
So what may have been a quick £70 job for me has in fact turned into a £1,000 plus friggin’ nightmare of public liability insurance claims and all the bad feeling and ill-will that goes with it. So far, whilst my insurance will cover all the potential costs involved, it has cost me over £200 in time, materials and excess insurance charges. I am well and truly not happy! 👿
The lesson I have learned here is: Do NOT buy pattern (so called “equivalent”) elements from Connect Distribution Services Limited no matter how strong the temptation. As they are sub-standard, don’t work, don’t fit. JUST DON’T GO THERE, DON’T DO IT!!!! 😉
Note to C.D.S.L ( I will be contacting you shortly over this problem and will be claiming compensation) 👿
Yours truly
Pi**ed off 👿
March 31, 2007 at 3:26 pm #209465goosegreen
ParticipantRe: Pattern Heaters: A cautionary tale 🙁
Martin, Very sorry to hear of your problem but you are not alone i am sure, Once fitted a Connect pattern element to a bosch oven and as soon as I turned it on to test it got an almighty bang and flash from the oven. Took the company fuse out and I had to hang around for 2 hrs waiting for the lecy guy to come and replace It. As I have stated in previous post I avoid pattern elements like the plague. All the best with this one, let us know how Connect react
Goose
March 31, 2007 at 6:30 pm #209466timdowning
What a nightmare. Last year i had two leaks caused by connect universal fill hoses. These are the only two claims i have had in twelve years.
I never pursued this with connect as how do you prove you fitted the part correctly???
Hope Connect react suitably in your favour!
March 31, 2007 at 7:08 pm #209467petalpop
sorry to go the other way with this but i fit pattern elements to cookers and washing machines and have never had a problem
March 31, 2007 at 7:12 pm #209468goosegreen
Tim, What the problem with the fill hoses? as I nearly had a major disaster with one I had fitted.
March 31, 2007 at 7:39 pm #209469timdowning
Both hoses sprung a small leak after a few weeks. I do remember someone saying some time back they had an uncrimped hose. Mine were crimped. but i think the washer was inadequate.
March 31, 2007 at 7:59 pm #209470goosegreen
Tim, It was me who posted about the hose not being crimped. Seems to be a one off, But thanks for the reply.
GooseMarch 31, 2007 at 8:30 pm #209471wilf
had this a few years ago bosch “genuine “element from wash vac (yes that long ago) replacement leaked as well or it would have but a good tug proved that even though it was tight I could pull it out. as I had thrown away the original I had nothing to compare with. howeaver the next element again genuine was different the rubber had a shoulder on it and could not be budged. everyone denied everything but I got the distinct impression that the problem WAS known about and was PROBERBLY dodgy imported stock. apparantly the automotive and aerospace industry is plagued with fake spares. was this a similar case? I dont know. I dont think that any of the supplier would allow poor quality product to be sold on purpose but the ammount of stock shifted and the ammount of hands passed through could be an open oppitunity for the less than honest.
wilf
March 31, 2007 at 10:17 pm #209472suedehead1
i had the same with a bosch element from washvac, tightened up the nut nice and tight gave the element a tug it came away in my hand.
when compared to the original there was a much smaller rubber flange on the new one which was supposed to be genuine.April 1, 2007 at 8:38 am #209473Martin
wilf wrote:genuine was different the rubber had a shoulder on it and could not be budged.
That’s exactly the problem here Wilf. The genuine element has a rubber gasket with a raised flange (shoulder) so it cannot be compressed into the oval heater plate. The cheap and nasty pattern ones (no only supplied by Connect, I’ve since discovered 😉 ) have no flange on them. On tightening the nut, the pressure plate squashes the rubber into the oval heater plate rather than allowing it to swell and compress against the tub aperture. Once the machine fills, the water lubricates the rubber and OUT SHE POPS….!!! 😯 😯 😯
http://img444.imageshack.us/img444/2984/heaters1yg8.jpg
UNCOMPRESSED
http://img134.imageshack.us/img134/9672/heaters2bj9.jpgWITH PRESSURE PLATE TIGHTENED
April 1, 2007 at 9:36 am #209474suedehead1
what a wonderful explanation martin
April 3, 2007 at 5:26 pm #209475effzedarr
Getting back to these heaters ,but is it me or are they getting harder to get out than the ones of yester year? Had one on a HTPT W/Dryer last week it was a sod to come out, talk about scraped knuckles!
April 7, 2007 at 10:12 pm #209476squadman
I have also thought that some of the elements are reluctant to remove especially some of the Hotpoints.
April 8, 2007 at 8:01 pm #209477eastlmark
ModeratorRe: Pattern Heaters: A cautionary tale 🙁
You guys obviously dont remember the old Zanussi SL heaters, Absolute pigs and would slit your wrist on the back panel opening at the same time. I think newer machines are easier to remove heaters, its just the plastic drum construction allows little scope for leaverage.
April 10, 2007 at 11:10 am #209478Goatboy
Any word on this from Electrue yet, Martin? 😕
