Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool adg7540 dishwasher cold water only
- This topic has 45 replies, 12 voices, and was last updated 19 years, 7 months ago by
Butch.
August 15, 2006 at 9:44 pm #19980
Butch
ParticipantMy 3 year old adg7540 has stopped heating the water during wash cycle. All cycles work as normal other than water is cold I assume it is the inline heater element, does anyone know how to change this component or better still point me in the direction of a service manual
regards
August 15, 2006 at 9:49 pm #185241gegsy
ParticipantRe: Whirlpool adg7540 dishwasher cold water only
Hi Butch
With the appliance unplugged you will need multimeter to check resistence of heater to confirm its failure.
As for diagrams may I refer you to top of this forum namely…Professional Advice in the Public ForumsPenguin45 wrote:Advice in Public Forums.
8/ Please do not ask for wiring diagrams, schematics or for us to sort out any wiring problems over the internet. We cannot judge how competent you are nor the future readers of any thread, we’ll try to point you in the right direction but that’s as far as we can legally go.
Regards
August 16, 2006 at 8:19 pm #185242DentedPorsche
Failure of the heater should give an error code. No hot water, no error code and completing the cycle is normally a faulty module.
Test the heater as Penguin suggests, if it checks out as being OK it’s more than likely a faulty module.DP
August 16, 2006 at 8:37 pm #185243gegsy
DentedPorsche wrote:Test the heater as Penguin suggests
I resemble that remark 😆
August 16, 2006 at 9:20 pm #185244Penguin45
I suggest you test the heater…….
There, is that better now?
:p45:
August 16, 2006 at 10:59 pm #185245gegsy
I think DP has telepathetic powers 😆
August 17, 2006 at 8:46 pm #185246Butch
Thanks for the advise guys, heater tested 0.028K Ohms good or bad?
regards Tony
August 17, 2006 at 8:49 pm #185247gegsy
Thats fine but you need to set the meter range correctly.
It should have read 28ohms which is about right for the heater.Greg
August 17, 2006 at 8:56 pm #185248Butch
My mistake if 28 ohms is correct for the heater where to next?
regards Tony
August 17, 2006 at 9:02 pm #185249gegsy
Its either going to be a faulty module or faulty NTC which Ive had in the past even though its not showing a fault code flash/s.
I think its going to be engineer time in all fairness, please check the link below.Cheers
August 17, 2006 at 9:09 pm #185250Butch
Thanks for your help and advise Greg, I will contact the recommended engineer
regards Tony
August 17, 2006 at 9:18 pm #185251gegsy
You very welcome Butch, let us know how you get on 😉
August 18, 2006 at 8:39 am #185252DentedPorsche
Sorry Gegsy, was in a rush when I answered this one and I credited it to the wrong person. 😕
DPAugust 18, 2006 at 8:46 am #185253gegsy
DentedPorsche wrote:Sorry Gegsy, was in a rush when I answered this one and I credited it to the wrong person. 😕
DP:rotfl:
August 19, 2006 at 7:38 am #185254Butch
The engineer that your system didnt fancy it ………………… too far away 22 miles no less. Will try to find another one! Not getting on too well
regards Tony
