Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool adg7540 dishwasher cold water only
- This topic has 45 replies, 12 voices, and was last updated 19 years, 7 months ago by
Butch.
August 20, 2006 at 9:32 pm #185255
Butch
ParticipantRe: Whirlpool adg7540 dishwasher cold water only
New development …………….. now jumps from programme selected to the rinse programme and beeps repeatedly 🙁 no engineer yet but it is the weekend, any ideas chaps, if I know what to change I am more than capable of doing it myself
regards Tony
August 20, 2006 at 9:38 pm #185256gegsy
Good news then 😀 Its the classic NTC fault.
P/no 481228268035 which is HERE (now part number 481228268051)
GregAugust 20, 2006 at 10:16 pm #185257Butch
Thanks for your advise i have ordered the NTC will let you know how it goes
regards Tony
August 22, 2006 at 9:10 pm #185258Butch
ParticipantUniversal NTC arrived todayas promised. Good clear instructions, simple to fit and best of all it immediately solved the problem. Thanks very much for your help and advise Greg and thanks to UKWhitegoods for such a helpful and informative web site
regards Tony
February 23, 2007 at 10:35 am #185259MrJ
I am having very similar problems to the OP.
Dishwasher goes through cycle but does not heat/dry.
I got a local engineer (whirlpool registered) out to have a look and they have replaced the NTC with no success (on 3rd attempt – they brought 3 different NTC parts on 2 different occasions). I have had a look at images for the NTC on other sites and they differ somewhat from mine. (mine has spade type terminals with blue wires that go to a connector.) To be honest he was stumped as he expected error codes on the panel. He kindly left me a copy of the error codes and what they mean just in case it starts flashing them. I have put the machine through a test cycle as described in the manual and all it does is start flashing when holding down the start while turning on the machine, as expected, when I start the test cycle it just steady flashes of/on with no pauses.
Anyone have any further suggestions.
TIA
MrJ 😉February 23, 2007 at 8:21 pm #185260Penguin45
Strictly speaking, a steady flashing with no pattern is F1 – the ntc sensor. If your tech has tried replacement of the part (they have been updated BTW) then the fault more or less has to be the computer board itself.
Penguin45.February 25, 2007 at 10:09 am #185261MrJ
I ran it through the check program again. This time shutting the door. It seems to want to do a rinse (as this si the program selected). I cancelled the program and then ran it through a 65 Degree C program and it seemed to work OK 😮 .
I am doing the same program as I type to see if it works again.
Hopefully it’s not a new board as I think I saw them for £100+.
MrJ 😉
->Edit 27-2-07
Well the machine seems to be working for the moment. If it goes again I will get a new (different brand) machine.Thanks for your help
April 24, 2008 at 4:22 pm #185262pinchy100
I have a similar problem with my ADG7450, dishwasher runs through complete cycle but does not heat water, although the machine heats up at the end drying part of the cycle. I have checked the NTC, reads 70kohm when cold and resistance reduces as I pour hot water over it. Checked all contacts, & wiring continuity, all OK.
If I unplug the NTC from the pcb it starts beeping and flashing continuously.
Before I spend £40 on a new part, can anyone confirm that it is the NTC that is faulty? ThanksApril 24, 2008 at 11:33 pm #185263Penguin45
Nope, no confirmation. Some work, some don’t, regardless of the reading. NTC is cheaper than a PCB though. As a repairer, I carry the NTC as a stock item, which gives me the option of substitution to check. Usually works, but no guarantees.
Sorry.
Stay safe, power off when working on the machine.
April 25, 2008 at 7:00 am #185264pinchy100
ParticipantPenguin45, thanks for the info, guess I’ll order an NTC & hope for the best.
cheers
SteveApril 30, 2008 at 8:07 am #185265pinchy100
ParticipantNTC ordered Monday, arrived & fitted Tuesday, all working well now. Many thanks to Penguin45 for your help & UK Whitegoods for prompt despatch of NTC.
June 27, 2008 at 9:49 pm #185266Eoin
I have an ADG7540 that might have a simalar problem.
It starts fine. Does a quick rinse. Then fills with cold warter. But then stops. Nothing happens.
If I hold down the start button it drains and stops.
How do I check this HTC?
Or does anyone have suggestions?
Cheers,
EoinJune 27, 2008 at 11:31 pm #185267Penguin45
After fill, it should circulate….. If it doesn’t, you’d better have a read of THIS.
For anything other than circulation problems, you should get the flashing start lamp as a fault indicator.
November 19, 2008 at 8:09 am #185268pinchy100
Back in April the NTC failed on my whirlpool ADG7450, got a new one from UK Whitegoods, & it has been working fine until now.
The washer goes part way through a wash, water heats ok etc but then starts beeping/flashing continuously & the rinse lamp is lit.
UKW kindly offered to replace the NTC under warranty & I returned it but they’ve metered it against a new one & it is the same.
Any ideas?
ThanksNovember 20, 2008 at 12:05 am #185269Penguin45
Fickle sort of beast, your Johnny NTC. I have had them dead out of the packet before now – give a nice reading in kOhms on the test meter – still doesn’t work. I can only suggest that you give the contacts on the pcb a thorough clean and the edge connector a bit of a pinch to improve the contact pressure. Failure of the temperature control circuit on the PCB itself is possible, but unusual.
