Whirlpool adg7540 dishwasher cold water only
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool adg7540 dishwasher cold water only
Viewing 15 posts - 1 through 15 (of 46 total)
  • #19980
    Butch
    My 3 year old adg7540 has stopped heating the water during wash cycle. All cycles work as normal other than water is cold I assume it is the inline heater element, does anyone know how to change this component or better still point me in the direction of a service manual
    regards
    #185241
    gegsy
    Re: Whirlpool adg7540 dishwasher cold water only
    Hi Butch
    With the appliance unplugged you will need multimeter to check resistence of heater to confirm its failure.
    As for diagrams may I refer you to top of this forum namely…Professional Advice in the Public Forums
    Penguin45 wrote:Advice in Public Forums.
    8/ Please do not ask for wiring diagrams, schematics or for us to sort out any wiring problems over the internet. We cannot judge how competent you are nor the future readers of any thread, we’ll try to point you in the right direction but that’s as far as we can legally go.
    Regards
    DentedPorsche
    Failure of the heater should give an error code. No hot water, no error code and completing the cycle is normally a faulty module.
    Test the heater as Penguin suggests, if it checks out as being OK it’s more than likely a faulty module.
    DP
    #185243
    gegsy
    DentedPorsche wrote:Test the heater as Penguin suggests
    I resemble that remark 😆
    I suggest you test the heater…….
    There, is that better now?
    :p45:
    #185245
    gegsy
    I think DP has telepathetic powers 😆
    Butch
    Thanks for the advise guys, heater tested 0.028K Ohms good or bad?
    regards Tony
    #185247
    gegsy
    Thats fine but you need to set the meter range correctly.
    It should have read 28ohms which is about right for the heater.
    Butch
    My mistake if 28 ohms is correct for the heater where to next?
    regards Tony
    #185249
    gegsy
    Its either going to be a faulty module or faulty NTC which Ive had in the past even though its not showing a fault code flash/s.
    I think its going to be engineer time in all fairness, please check the link below.
    Cheers
    Butch
    Thanks for your help and advise Greg, I will contact the recommended engineer
    regards Tony
    #185251
    gegsy
    You very welcome Butch, let us know how you get on 😉
    DentedPorsche
    Sorry Gegsy, was in a rush when I answered this one and I credited it to the wrong person. 😕
    DP
    #185253
    gegsy
    DentedPorsche wrote:Sorry Gegsy, was in a rush when I answered this one and I credited it to the wrong person. 😕
    DP
    :rotfl:
    #185254
    Butch
    The engineer that your system didnt fancy it ………………… too far away 22 miles no less. Will try to find another one! Not getting on too well
    regards Tony
