Zanussi WJD 1457 w washer/dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi WJD 1457 w washer/dryer
Viewing 15 posts - 1 through 15 (of 48 total)
  • #91859
    BJC4
    On drying fluff filter chamber fills with water and heater isn’t coming on. Whatever cycle it is set on ie 15 30 40mins. finish in 11mins. On washing and spin drying everything works ok. I realize the heater doesn’t come on for the first 10 mins. Also the timer works ok when set for 10 mins
    #449502
    Re: Zanussi WJD 1457 w washer/dryer
    The condenser chamber should not fill with water so therefore it is blocked with fluff at the bottom, needs clearing out !
    #449503
    BJC4
    Thanks will try that
    #449504
    BJC4
    Checked for fluff all seems ok. Fills with water after 1min of dryer time
    #449505
    It should not fill AT ALL!
    It is blocked clearly.
    #449506
    BJC4
    Will the blockage be around the condenser chamber or could it be the condenser itself. I’ve taken a couple of hoses of the chamber and taken the pump out they seem to be clear. Is their an easy way to get into the chamber. Thank you for all your help I appreciate it
    #449507
    on that model the rear case comes off as a wrap. it splits in the centre of the case at the sides. only undo the screws for the rear half. once off access is great
    BJC4
    Thank you for your help. Yes the condenser was fully blocked and their was a wire of the temp probe. After a good clean out and reconnection of the wire the dryer worked fine. Unfortunately after using it a couple of times the reset/skip switch is not working, on investigation have found the switch on the cct board has broken offor. To my disappointment I’ve been told this part iso no obsolete so it looks like a new washer. So regards and thank you for your help and advice
    #449509
    what part has actually broken. if its the electrical switches on the board they are normally used on other things. I swap them from other boards all the time
    BJC4
    Yes it’s the actual push switch on the cct board
    #449511
    BJC4
    Thanks Dave I have now changed flty switch on the board with one of the switches we never use all working OK. Thanks once again for your help
    #449512
    Wishywashy62
    electrofix wrote:Re: Zanussi WJD 1457 w washer/dryer
    Hi how do I remove the front panel as I need to get to the water chamber hope you can help thank you
    #449513
    you cant remove front panel as the machine looses structural integrity if you do
    you can remove the filter unit without removing it
    Specialist01269
    Think he’s talking about the control panel buddy.
    #449515
    Specialist01269 wrote:Think he’s talking about the control panel buddy.
    I was thinking he needed to remove the filter / pressure chamber unit
