Zanussi WJD 1457 w washer/dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi WJD 1457 w washer/dryer
Viewing 3 posts - 46 through 48 (of 48 total)
  • #449546
    it has one of each type. each with its own tube from the pressure chamber which must be clear to work properly. The older one is also used in the heater circuit to prevent the heater coming on when there is not any water in the tub
    which heater did you disconnect washer or dryer ?
    Wishywashy62
    Washer, tried to post it seven times not sure if you can see it it’s leading me to error
    #449548
    well if you have no wash heater all the programmes will take longer and its a wonder the machine doesn’t stink
