Hi There,
Tried it last night after setting the size and it worked. I will try it again tonight to make sure that it is still in its ‘memory’
Thank you all for your advice.
Andrew
Thank you for that I will give it a shot-how do you check for kinks please as I was able to blow through the hose and heard it bubbling-if the module needs replacement I assume that this is an expensive item.
