Clive Braham
ParticipantRe: Candy CDI1012/B-80 dishwasher
It was the flow meter. Not the connection, but the flow meter itself. Hope this helps someone in the future.
Clive Braham
kwatt wrote:It is on Gias Clive, you might need to be a bit lateral to find it though.
All LEDs lit/flashing is the anti flood tripped.
Leak or faulty anti-flood device I would think.
Thanks for that. I’m told the flow meter can have a bad connection and cause the same fault display as the anti-flood so I have ordered the water tank with the integral flow meter. I’ll report back with the results so it can help others in the future.
Clive Braham
ParticipantRe: teka adw659fi
robinsonrobbo wrote:cust says machine runs for about 5 mins then beeps and the flashes.
there are 5 lights the firsr 3 flash 4th off and fifth (the cycle she had it on)is lit solid.any body got any fault codes?cheers chris
I’ve just been to the same machine with the same problem. Can anyone help with the fault code? I’m thinking flow meter.
Clive
Clive Braham
ParticipantRe: Can I offer my own annual appliance cover?
Thanks to all, especially Jackal for the very comprehensive reply.
Clive
Clive Braham
Thanks for that Martin. This must be why no one else does it!
Clive
Argyll Appliance RepairsClive Braham
ParticipantRe: Indesit IWDC6143UK
Clive Braham wrote:
rocker wrote:
Did you check the ohms reading of the NTC’s are in range..I dont know the autual values but someone on this site will.I haven’t checked that. I’ll give it a go. Thanks for that, Rocker.
Just in case it helps anyone in future – Rocker was right. The dryer NTC was O/C, causing the drain pump circuit to shut down 1 second after getting a signal. Thanks Rocker.
Incidently the values of both NTC’s should be around 20Kohms at room temperature.
Clive
Clive Braham
rocker wrote:Did you check the ohms reading of the NTC’s are in range..I dont know the autual values but someone on this site will.
Clive Braham
Still stumped with this repair. I checked everything for an earth fault but all’s coming up fine. Also disconnected everything in turn to try to isolate the fault. No change.
I noticed that the dryer fan powers up for the same split second as the pump gets its power. Although the board is brand new I am going to send it off to get checked out but the mystery is that the same fault was present with the original board. ❓
Has anyone else come across this problem and can give me more pointers? :rolls:
Clive Braham
ParticipantRe: Diplomat Induction hob HJA1633 error 22
eastlmark wrote:have the list of eror codes but there is no E 22.
OK thanks. She is just going to get a new hob now as there is a Beko touch control induction hob available for £199. Whichever board is faulty on the Diplomat she’d be looking at a similar sort of price for a repair.
Clive Braham
No one got anything at all on this or point me in the right direction?
The same hob also comes branded Lamona and Howdens HJA6133. Stoves model number 444449113, Diplomat AAA1473. I can’t find error E22 anywhere. Help!
Clive Braham
Criscold wrote:I had this a couple of months ago, check NTC on side of dryer duct for earth fault and also the one in the wash heater
Colin
Thanks for that Colin. Will do!
Clive
Clive Braham
ParticipantRe: Hotpoint WDL540 washer dryer
Ok, thanks a lot for all your help. 😀 I’ll check the brushes but it was the same symptoms before I fitted the new brushes. Looks like a new motor is called for. :rolls:
Clive Braham
Thanks for the reply. The door actually locks and it doesn’t unlock at all after the 6 clicks. I checked the wiring between motor and module – all fine. The machine actually started this time, on a drain and then on a rinse but as soon as the motor wanted to kick in it aborted and gave the 6 cliks of the door lock.
When I fitted the new brushes it sounded like it was sparking on fast spin. I’m leaning towards a faulty motor but none of the tabs are down to earth and I don’t know what resistances to expect between each tab.
Anyone got the diagnostics? It would probably help.
Clive Braham
ParticipantRe: Cookers (Homark) BI 1000X
Sorry all, I forgot to mention the appliance in question is a washing machine. Anyone know how a part number for the sump to pump hose?
