dan_uk_1984
ParticipantRe: Miele T234C Very Steamy – Not much condensing
Hi, Thanks for your reply.
I’ve checked the drain tube and that seemed fine. It just seems to take slightly longer than normal, plus there was a some condensation inside the machine when I took the lid off.
Dan
dan_uk_1984
ParticipantRe: Miele T230C Condenser – Doesn’t turn off
Replaced the carbon blocks, but unfortunately the problem remains.
Does anyone know exactly where the sensors are so I can take a look at them and clean then if necessary?
Obviously I’m loathed just to keep throwing money at it.
Thanks,
Dan
dan_uk_1984
Many thanks for the part number, and these are responsible for the moisture sensing?
Dan
dan_uk_1984
Sorry to bump my own thread, but any more info on this?
Thanks,
Dan
dan_uk_1984
Right, I’ll pop the top off later and take a look!
Can these carbon blocks be replaced?
UPDATE:
They are very warn, any thoughts on part numbers or suppliers?
dan_uk_1984
Penguin45 wrote:One of the sensors will have failed, so the pcb is no longer reading the temperature gradient between the front and the rear – it probably thinks the laundry is still damp.
If you are a little patient, one of the Miele chaps will give you a more definitive answer. Bear in mind that this is a Miele appliance – if it needs parts, you’re going to pay. Lots.
Ah so that’s how it does it, are these temperature sensors accessible? Could it be that they have got covered in fluff and are too insulated to give a correct reading?
dan_uk_1984
washermanuk wrote:First thing to check is the two carbon blocks mounted on top running on a track attached to the drum for wear? If badly worn they will jump off the track at certain points where screws are used for mounting the track!!
Power off please!!!!
No LED lights flashing?
Hope this helpsHi thanks for the reply, the two blocks on the top are fairly worn. But I thought they were for the motor, are they related to the moisture sensors?
No flashing lights or anything untoward.
Dan
