Derby_rob
  • in reply to: Zanussi 6120p totally dead #446146
    Derby_rob
    Re: Zanussi 6120p totally dead
    Thanks. Theres a used one on ebay at the mo for £18 so may give that a punt.
    in reply to: Zanussi 6120p totally dead #446144
    Derby_rob
    Hi – thanks for the response. The product code on the sticker by the door is 914906418
    in reply to: Ariston A1435 Margherita Fault Code 7 and other problem #382119
    Derby_rob
    Re: Ariston A1435 Margherita Fault Code 7 and other problem
    Have taken the PCB out fully now, looks like dry joints on RL7 I’ll try soldering them up tomorrow and if that fails I guess it’s a new PCB or new WM.
    Thanks for all your help.
    in reply to: Ariston A1435 Margherita Fault Code 7 and other problem #382117
    Derby_rob
    The connector on the end of the blue wire that attaches to the element and goes to the PCB is very black at the PCB.
    in reply to: Ariston A1435 Margherita Fault Code 7 and other problem #382116
    Derby_rob
    Got 30 ohms across heating element and continuity. Can’t do an insulation test as haven’t got a megger.
    Other than the earth terminal, what are the other terminals for (2 together) – some kind of temp sensor? – I don’t get continuity across those if that’s relevant.
    in reply to: Ariston A1435 Margherita Fault Code 7 and other problem #382115
    Derby_rob
    Wow! – Thanks for the quick response. I’ll have a go this evening.
    Thanks again.
    in reply to: Ariston A1435 Margherita Fault Code 7 and other problem #382113
    Derby_rob
    Hi – thanks for that,
    What sort of resistance am I looking for? – I haven’t delved into taking washing machines apart before but have had some electrical experience so would like to have a go myself.
