dja_1
  • in reply to: Whirlpool ADP4403 #209724
    dja_1
    Re: Whirlpool ADP4403
    Finally got working; cleaned again with almost boiling water and toothbrush. As the original engineer totally misdiagnosed the problem am I in a position to demand the 47 pounds I paid out for the duff advice??
    in reply to: Whirlpool ADP4403 #209722
    dja_1
    Have cleaned and when turned back on the water used to clean has drained ok. It is not taking in water but the four flashes sequence is the same?
    in reply to: Whirlpool ADP4403 #209720
    dja_1
    The black grid is a bit blocked with gunk, what is the best way to try and clean it?
    in reply to: Whirlpool ADP4403 #186129
    dja_1
    Definitely 11 flashes; had a look for the optical water indicator but not sure what I am looking for, what does it look like? Also, no UKW engineer in my area (RH1 postcode), where should I go if I need an engineer?
    Thanks for help.
