Gavin.allport
  • in reply to: zanussi zwg6161 #439804
    Gavin.allport
    Re: zanussi zwg6161
    If you’re in the diagnostic menu the last option will give you a fault code
    in reply to: zanussi zwg6161 #439800
    Gavin.allport
    Re: zanussi zwg6161
    Resistance sounds about right. If you put the machine on a spin cycle does it do the same? Have you checked the motor brushes? When the brushes go you can often get odd faults.
    in reply to: Samsung rsg5ucrs power failing #439759
    Gavin.allport
    Re: Samsung rsg5ucrs power failing
    Hi Tom,
    Firstly have you checked if your machine is on their product recall list? Or has any rework needed been done?
    http://www.samsung.com/uk/homevisit/?pi … t_20130524
    I’m not familiar with your exact model but there should be a thermal fuse on both fridge and freezer evaporators (normally have black and red cable) if these fuses go the fridge will stick in defrost mode. It’s also worth checking the resistance of the defrost elements as these are fairly common (test them individually and not from the connection they both plug into)
    Hope this helps
    Good luck
    in reply to: zanussi zwg6161 #439798
    Gavin.allport
    Re: zanussi zwg6161
    If it has a linear pressure switch you may have to reset it after manually draining the appliance.
    Turn the machine off pour in 1.5 litres of water then put on a drain cycle. You might have to do this more than once as they can be temperamental
