gavin_blair
ParticipantRe: creda continental twin fan oven
Right the controls caused the ‘no heat’ problem for upper oven, when powered on “24 hrs” in display was flashing, so changed that and its working OK now.
Still no heat in lower oven. No damage visible on the element. Is it possible for me to check if its OK? How?gavin_blair
ParticipantRe: Crusader condenser Tumble Dryer spins no heat
both discs on under side of stats look good not dished in.
any ideas
gavin_blair
Thanks whitevanman
Ok found GREEN spot stat. I have removed wires from both stats.
Now how do I check for continuety across these probably spoted stat oc. ??
how will I know if to replace stat?
If stat ok then what next?
March 6, 2006 at 9:41 pm in reply to: Creda Continental twin fan assisted main oven not heating #167599gavin_blair
ParticipantRe: Creda Continental twin fan assisted main oven not heatin
Ok the makers label for this oven is on the front bottom edge under the door. It has become worn and the model number is now illegible. Looking through the many receipts I have found one for Creda dated 1993. Model No. 48167. for all I know this could be an electric kettle. 😳 any good?
March 5, 2006 at 10:37 pm in reply to: Creda Continental twin fan assisted main oven not heating #167596gavin_blair
Hi Dave, serial no. 36 1 00089
