James montgomery
ParticipantRe: Cooker trips when 1 ring is switched on
element or regulator. Likely a spillage onto regulator below knob.
James montgomery
ParticipantRe: Hotpoint FTCL 871 GP – Light
there is a float that moves up and down on the water level. once pump has pumped water the float should drop. sometimes it doesn’t an simulates that its full so it goes around with no heat.
Just tap the bottom grey box gently at bottom behind dryer to drop it.
If you’ve no water in draw possibly pump itself.James montgomery
ParticipantRe: Hotpoint TCHL 73 BRP Condenser Dryer
you may be putting it on delay timer by accident.
Could be the sensors are picking up all different readings!
sensor dry need to be correct weights, same material and ideally same thickness or sensor dry can be conned!!!
Failing your doing all that I say there may be issue with module.James montgomery
ParticipantRe: Cannon C60DPXF fan & light died at same time
Some versions it uses the element in roof of oven to preheat for small amount of time , once reaches temp the fan motor cuts in with circular element. May be that you were looking fan instant movement and never got it!!
are you sure there’s heat in the main oven? normally the selector switches are working with the stat if there’s heat there.
Possibly if no motor then it could be the door switch, or selector switch.
Look out for the blade angle on motor jamming against cover as new blades slightly bend towards cover from original blade.
Lastly looks like the module!!!James montgomery
ParticipantRe: Staff
Its other engineers at Peterborough training,like franchise owners and employees. The mix and discuss job prices etc.
Turns their head and don’t think of overheads, just how much they make to how much each jobs worth.
Hard part is keeping them after two years or so when they think they don’t need you anymore.
They setup themselves an you make you work pond bigger and indirectly are in competition with yourselves. No protection !!Going through something similar
