JM_2
ParticipantThanks Dave
JM_2
ParticipantHere is the picture and price of main cover :
https://www.siemens-home.bsh-group.com/uk/shop-productlist/00611314JM_2
ParticipantHi Dave,
Thanks for the tip.
I can see water dripping behind the water inlet. Below the main cover.
https://www.siemens-home.bsh-group.com/uk/shop-productlist/00683397
I also need to remove the thread bolt which needs an allen key. Not sure which size.
https://www.siemens-home.bsh-group.com/uk/shop-productlist/00622267
JM_2
ParticipantHi,
Did you manage to sort this problem.
Ideally, you need an allen key. I also wondered what size allen key is required. As I also need to remove it and check.
I was planning to remove the whole of water inlet contraption and clean it.
There is also another small interior water cap that need to be undone with an allen key. Need to know the size please.
October 22, 2019 at 3:04 pm in reply to: Siemens Dishwasher SN25M230UK/01 Error 09 Water Not Heating : Not Drying #464006JM_2
ParticipantHere is the link to the Dishwasher :
https://www.siemens-home.bsh-group.com/uk/supportdetail/product/SN25M230UK/01
Link to the heat pump . It is different to the original. It’s a replacement . Part Number 00654575
https://www.siemens-home.bsh-group.com/uk/shop-productlist/00654575
[h=1]Heat pump EDS II.Gen. and wire harness set for modification 00654575[/h] https://media3.bsh-group.com/Product_Shots/600×337/MCSA00479946_654575-Heizpumpe_def.jpgJune 12, 2011 at 6:44 pm in reply to: Multimeter : Multitester : Continuity tester. Which is best. #353438JM_2
ParticipantMultimeter : Multitester : Continuity tester. Which is best.
hi,
Thanks for the info.
Much appreciated 🙂
JM2
June 11, 2011 at 2:20 pm in reply to: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights #353349JM_2
ParticipantSiemens Washing Machine WXL 120GB/01 Stopped : No Lights
AppliancemanThanks. Not sure how I get to the element. Will I have to remove the front panel.
How would I know that the element has gone. And will replacing it solve the problem.
JM2
June 11, 2011 at 11:36 am in reply to: Multimeter : Multitester : Continuity tester. Which is best. #353436JM_2
Hi Martin,
Thanks for the link.
There are quite a few meters there.
Which one would you recommend please : to carry out test on above appliances etc .
Also when I had a problem with my fridge there were few tests recommended. One of them said :” After you dust the relay off, take a good look at it. You should see two plug-type terminals marked “S” and “M” and the slip-on terminal marked “L.” Set your multitester to read ohms (usually the X1 or RX1 setting). Set the relay on a flat surface so that the “S” and “M” terminals are on the bottom. ”
Like to get one that can do the above. Not sure what it means by” the X1 or RX1 setting “.
Also saw one in B & Q :Is that any good :
http://www.diy-spares.com/cgi-bin/produ … tprecision
Will that be adequate for the purpose.
ThanksJM_2
June 11, 2011 at 10:10 am in reply to: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights #353347JM_2
ParticipantRe: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights
Applianceman2010 wrote:I’m just thinking mabe the “click” was the PCB bringing on the heater and it blew, taking the PCB with it …. 😐 just a possibility.
Hi,That doesn’t sound too good. Not very good design if the PCB goes just because the heater element has gone.
So it’s not worth changing the heater element ?
Thanks for all the assistance.
JM2
June 10, 2011 at 10:03 pm in reply to: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights #353345JM_2
Applianceman2010 wrote:Heater?
Hi Applianceman2010,Thanks for the reply.
Are you saying that the Heating Element has gone ?
If they have gone, would all the lights go off.
How can I be sure ?
Also if the heating element has gone, would I normally be able to use the spin or pump programme. Or cold wash ?
None of the lights coming on !
ThanksJM2
June 10, 2011 at 9:50 pm in reply to: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights #353344JM_2
Applianceman2010 wrote:Are you SURE one of the brushes havn’t snapped or jammed in the holders?
Hi,I have checked the motor brushes. They are intact and OK.
JM2
June 10, 2011 at 8:47 pm in reply to: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights #353343JM_2
Here is the link to the manual which shows the Dials and buttons ;
Link to Manuals :http://www.bosch-home.co.uk/download-pr … nuals.html
ThanksJM2
June 10, 2011 at 8:45 pm in reply to: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights #353342JM_2
Hi,Thanks for that, I’ll check it.
JM2
June 10, 2011 at 7:37 pm in reply to: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights #353340JM_2
Correction. I am now being told that it went ‘ click ‘ and then stopped !
ThanksJM2
June 10, 2011 at 5:02 pm in reply to: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights #353338JM_2
kelland wrote:some bosch machines (same as siemens) go into fault code when the brushes go and have to be cleared, on bosch machines if my memory serve me right is….turn dial to 6 ‘o’ clock posistion, press and keep holding spin speed button, turn one notch clockwise then 3 seconds later let go of spin speed button then turn to off posistion, but before all this check brushes
Hi Kelland,Thanks for the reply.
I had checked the brushes. They seemed OK when I checked two weeks ago.
It has worked few times and now has suddenly gone. There is lot of water left inside.
Trying to work out your instructions. There are two dials
One for the programme on the left.
and
the right dial is for spin speed.
There are 5 buttons from left to right ;
1. Remaining Time / Time delay
2. Short Wash
3 Extra Rinsing
4. Less Ironing
5. Start
http://www.siemens-eshop.com/eshop/siem … XL120GB/01
So not sure which ones I turn and hold.
ThanksJM2
