ken_mayall
  • in reply to: Indesit WIXE 12 All display & control lights flashing #430287
    ken_mayall
    Re: Indesit WIXE 12 All display & control lights flashing
    Ok fitted new cap as per others on board and now seems to be working fine so thanks for advice. Just a note to readers, don’t always believe that what you find online is correct as that was what led me down this path. Always worth getting a second opinion on things. Thanks
    in reply to: Indesit WIXE 12 All display & control lights flashing #430286
    ken_mayall
    Thanks Dave, think you have it there. I followed steps from an on-line video and think they got their polarities mixed up as have now seen 2 more which contradict the 1st one plus other advice. Will check other caps for guidance and try again with a new cap. Cheers
    in reply to: Hotpoint/Ariston washer/dryer CAWD 129EU #427343
    ken_mayall
    Re: Hotpoint/Ariston washer/dryer CAWD 129EU
    Ok many thanks for your help, I will check it out
    in reply to: Hotpoint/Ariston washer/dryer CAWD 129EU #427341
    ken_mayall
    Ok in that case the lights on are 1,3 and 4.
    in reply to: Hotpoint/Ariston washer/dryer CAWD 129EU #427339
    ken_mayall
    Thanks for your reply and yes there are some vertical lights on, there are six lights on the panel. From top to bottom the lights on are 3,4 and six as well as the 5 continuous flashing along the bottom. Does this match any of the UK made machine’s error codes ? Any ideas ? Cheers, Ken
    in reply to: Whirlpool AWM043 pump running constantly #423631
    ken_mayall
    Re: Whirlpool AWM043 pump running constantly
    Thanks for the advice Dave, will do a quick visual check on the board and see if I can spot any signs of failure. Ken
    in reply to: Candy dishwasher showing er5 #415093
    ken_mayall
    Re: Candy dishwasher showing er5
    Multimeter is working ok so if it’s only showing less than 0 ohms that would suggest the heater unit, if it should read 30 ? Will also check control board for bad connections/burns and then will give it another run and see what the result is.
    Cheers
    Ken
    in reply to: Candy dishwasher showing er5 #415091
    ken_mayall
    Thanks for that Andy, thought it should be around there as that is normal for a heater element but wasn’t sure if it would be the same for a flow through heater. Any idea what the cause of failure would be ?
    Many thanks
    Ken
