kevin.mawhinney@lineone.n
  • in reply to: Whirlpool G2PDWI/1WH Error Code #214979
    Re: Whirlpool G2PDWI/1WH Error Code
    Hi Greg – I had a look at the water matrix and found that the flowmeter is indeed faulty. It has a crack in the glass reed switch which picks up the magnetic pulses from the impeller. It’s not responding when the impeller turns. Do you know if the reed switch, or its small circuit board are available separately from the matrix? If not, is the matrix available?
    Thanks for your help – Kevin.
    in reply to: Whirlpool G2PDWI/1WH Error Code #214978
    Hi Greg – Thanks for the info. I’ll have a look – Kevin.
    in reply to: Whirlpool G2PDWI/1WH Error Code #214976
    Plenty of water flowing in and the machine fills OK. Where is the flowmeter and how does it work?
    in reply to: Whirlpool Dishwasher NTC test #212821
    Re: Whirlpool Dishwasher NTC test
    Thanks for the suggestions. The pressure switch is fine. I’m going to try a new NTC probe.
    in reply to: Whirlpool Dishwasher NTC test #212818
    Should I buy a new NTC probe and try it? It’s cheaper than a new control board. On startup, the machine fills with water normally but then the buzzer sounds and the fault light starts flashing. The drain pump then starts up.
    Can you think of anything else I should try?
    Thanks – Kevin.
