Mark Davies
  • in reply to: Whirlpool American FF – – problem #418127
    Mark Davies
    Re: Whirlpool American FF – – problem
    Done , a trip to maplin sourced a relay , its a 12v but suitable for 24 v DC coil operation . ( 16 amp 240V ac switching )
    Desoldering the old one was the biggest part of the job . Replaced and all good in the world …
    in reply to: Whirlpool ice maker #417740
    Mark Davies
    Re: Whirlpool ice maker
    Just had one of these in bits .
    it could be either water supply to the ice maker or the dreaded relays and caps on the main board ?
    Any other symptoms like spluttering water from the water dispenser ?
    The IR unit has been reported on the net as a possible cause. Its on the left top of the freezer ( with the flappy door ) . This unit is a receiver of some description and is accessed removing the three screws .
    https://www.youtube.com/watch?v=N988_wHptUw
    in reply to: Whirlpool American FF – – problem #418126
    Mark Davies
    update .
    fridge-freezer-forum/whirlpool-afb6640-freezer-alarm-t32796.html
    after much searching and testing the boards a tap on relay 2 kicks the compressor in .
    So it ain’t always the caps !!!!!
    RELAYS REQUIRED SCHRACK T7NS5H1-24-WG-A 3 NUMBER AND RT314024 1 NUMBER .
    The single controls the compressor and is a 16 amp 24v Dc .
    AVAILABLE FROM CPC Farnell .
    Gear on order at £5 plus P and p . Update when done.
    in reply to: Whirlpool American FF – – problem #418125
    Mark Davies
    Update ..
    managed to get the compressor to go by switching on the mains with the freezer door open. Closed the door after start up and no bleeping . Unit cooled and freezer worked .Compressor ran warm but not too hot .However , this morning the dreaded — and bleeping was back .
    All caps changed on the main pcb , no scorching on the boards .
    the PCbs are so damn expensive willing to give the change components a go .But which one ?
    time for a service engineer ?
