mystic.bertie
ParticipantRe: Candy Grando E08 Error – GO DF800
Martin wrote:Did you inspect the PCB more closely for component damage?
Hi, i need to get it off for a proper look, from what i can see there is no damge but im limited as to what i can see, how does it come off?
mystic.bertie
Can anyone help me any further on this?
PLEAZzzzzzzzzzzzzzzzzzeeeeeeeeeeeeeeeeeeeee
mystic.bertie
I had a look with a torch but nothing obvious, should i remove it for a closer look, if so how do i remove the pcb does the knob on the front just pull off?
mystic.bertie
Hi Martin, can this be tested in any way?
mystic.bertie
Martin wrote:
mystic.bertie wrote:
Yeah made in china motor, are these far less reliable?Verry less rerriable…… Much lubbish! 😉
Hi, im afraid after fitting the new tacho the machine still does not work, same problem, fills and drains but does not rotate and then throws up the E08 error.
mystic.bertie
lol, cheers Mr Miyagi
mystic.bertie
Ok thats great, many thanks for confirming this. Ill get one on order and report back once its fitted and i hope its good news. Yeah made in china motor, are these far less reliable?
mystic.bertie
Hi Martin, sorry for the delay, here is pics and a video, are my setting correct and is the reading im getting correct?
cheers
video on the tube on you
https://www.youtube.com/watch?v=0u0l9s6 … e=youtu.bemystic.bertie
0.5 ? ohms, i was going by what i saw on you tube, test the resistanceNo the resistance is incorrect. Does it generate voltage when you rotate the armature? I guess not. 🙁
Don’t you just love those YouTube video’s. :rolls:
Sometimes youtube videos are useful, maybe not in this instance 😀
I did not check for voltage, what should i set my meter to and can i test it without refitting the motor?
thanks for your help, we will get there, i hope 😉
mystic.bertie
Ok i just tested the tacho and it is only going as high as 0.5.0.05 what? A magnetic tacho generator is axactly that, a generator, of voltage. It should register a rise in voltage and if it does, no matter how minimal, it proves it works.
0.5 ? ohms, i was going by what i saw on you tube, test the resistance, is this correct? SO does it look like my tacho ok?
mystic.bertie
Ok i just tested the tacho and it is only going as high as 0.5. Does this mean i definitely need to change the tacho.
mystic.bertie
i can borrow a better multimeter from work, ill test the tacho tomorrow night and report back. cheers
mystic.bertie
How reliable is testing the tacho with a multimeter?Very. Spinning the armature should generate current noticeable on a multimeter.
maybe i should get a decent multimeter and test it, i have one similar to this below, just a cheap screwfix one, so im not sure how reliable it is, i get a zero reading when turning the motor shaft.
mystic.bertie
Hi.
The terminal block was still attached to the bracket on the motor and there is lots of slack in the wiring so it does not look as though the cables got harmed.
mystic.bertie
SO is testing the tacho a bit of a hit and miss as i read a post where the guy got bad readings from the tacho, replaced the tacho and the brushes and still had the E08 error.
