Oscars domestics
  • in reply to: Noisey LG Recirculation Pump – Alternative? #430266
    Oscars domestics
    Re: Noisey LG Recirculation Pump – Alternative?
    I have changed a few of these. when the pump system is changed you need to check the pipe work up to the door seal too.. and the little outlet nozzle.
    as far as I know the only part is from LG, no other interchangeable parts available
    in reply to: Help E57 code on Bosch WAQ283S1GB/01 #430277
    Oscars domestics
    Re: Help E57 code on Bosch WAQ283S1GB/01
    Now the machine is empty i would run a drain cycle with the filter out . look insode to see if the pump impellor is spinning , if not the pump has gone, if it is check the waste pipe and u bend . then run the machine again..
    in reply to: Neff T1571 Hon – Flashing 0 #430423
    Oscars domestics
    Re: Neff T1571 Hon – Flashing 0
    I would say that a temp sensor on the module has gone. Trouble is, This is directly read by the power board. so would need the board
    in reply to: Electrolux EXW14450w drying issue #430452
    Oscars domestics
    Re: Electrolux EXW14450w drying issue
    Have you run the diagnostics do drag a code off?
    I would be looking at the NTC in the dryer duct connected to the condenser tank either that or your Heater Element for the drying side is going to earth
    in reply to: Bosch integrated fridge freezer #430410
    Oscars domestics
    Re: Bosch integrated fridge freezer
    Not that I want to advertise for anyone . but if you go on to A/O and put in the dimensions needed it will spit back the ones you can get. too many to list
