Paul Walker
ParticipantRe: F & P..GW508 Fault code
I reprogrammed it and set the size and something else (cant remember what now). But now it turns off after the final spin. So ignore the original post
Paul Walker
ParticipantRe: Smartdrive GW508 turns on and everything
Well, it fills up now. but I have no idea what the cause was.
There’s 2 possibilities.
1. I replaced the filters
2. The TV I purchased in Sept last year,
In Mar / April this year, I took it back to the shop.
Because, after watching TV for say 30 mins – It sounded like cicadas at the back of the TV.
The electrician / whatever you call them tested it, and found that it had a power supply PCB fault.
So I got it repaired under warranty (its got a 3 yr warranty). Once it was fixed, this washing machine has always filled up with water
But, when I did the diag test, (before I replaced the filters / when it wouldn’t fill), the cold and hot water did work / did fill the washing machine
Paul Walker
Managed to find it ta John. 426457. Thats the part for the reed/oob switch, Man its not exactly cheap here $66 $NZ !
Product code is 90105
Paul Walker
Anyone know the part # for the reed switch for the GW508K??
Paul Walker
This sounds like my prob the reed switch.
Since as this post says everything works, it turns on, the cold water does goes in after I press wash temp/power, then press the wash temp button again
May have to somehow remove the top deck to check it out
