Phil_s
ParticipantRe: Hygena hob control failed (again)
I presume that this is because it would need to de dismantled and I am not allowed to do that. If so, that is fine. Can you tell me if it is repairable by an engineer, or do I just cut my losses and replace it?
Kind regards
PhilDecember 12, 2005 at 6:56 pm in reply to: Hygena APL8224/1 – water remains after cycle ended #157317Phil_s
ParticipantRe: Hygena APL8224/1 – water remains after cycle ended
Thanks NWAR – I think I will be buying a new machine – this one has played up a wee bit too much.
PhilPhil_s
ParticipantRe: swapping BOSCH SGI43EO2GB for Hygena APL8224/1
Many thanks for the advice guys. I’ll have a look around.
PhilPhil_s
ParticipantRe: Hygena 8224 dishwasher
Thanks K,
I have emailed Dave.
Many thanks for your help.
PhilPhil_s
Thank you for that K,
Is there a way to look at the parts you are talking about? I searched around the web for any diagrams but could find none. The part you are talking about sounds like it could be it, though when I took the assembly apart as far as I did, I don’t recall seeing anything metal aside from the spray arm.
I am quite happy to purchase the part – at that sort of price it is a good bet. Does it come with any fitting instructions or do I have to guess?
DO I need to contact Dave separately to check availability – if so, how do I go about this?
Many thanks for your help today.
PhilPhil_s
Thank you K,
Don’t know how I missed that. It’s an APL8224/1.
I have had the lower spray arm off and that seems fine. It is the bit it is mounted on that seems to have the problem. Part of it looks as if it is worn out of shape, and it wobbles about a bit. Problem is I don’t know what it looked like and felt like originally. All I do know is that now after running the machine, the lower spray arm ends up leaning over slightly.
PhilPhil_s
Thanks for responding.
My paperwork only says 8224. Is there a plate on the machine somewhere that gives fuller details? If so, any idea where I might find it? There is nothing that I can see without pulling the machine out. If I need to do this, fine, but I’d like to know where I am looking.
Regards
Phil -
