PIP-pm-
Viewing 15 posts - 1 through 15 (of 24 total)
  • in reply to: virus/spyware #204674
    PIP-pm-
    Re: virus/spyware
    I use a hardware firewall and avg
    But best method to stop spyware is DON’T DOWNLOAD PORN 😆
    only joking norton in my opinion is like using a sledgehammer to crack a wallnut.
    and it blocks half the stuff you want it to access most of the time.
    in reply to: coin in tub #202544
    PIP-pm-
    Re: coin in tub
    no probs you do with it what you like 😀
    PIP-pm-
    Re: Getting the belt on the tension pulley – Hpt condenser d
    8″ long 1/4 inch drive socket shaft the 1/42 drive recieve end fits over the drive shaft and the belt slips on job done
    in reply to: coin in tub #202540
    PIP-pm-
    Re: coin in tub
    yes it is new one came courtesy of antonio merloni (see other link in rumours 😆 )
    in reply to: hotpoint wf250p no power #202559
    PIP-pm-
    Re: hotpoint wf250p no power
    EMW they should help
    http://www.emwelec.co.uk/
    in reply to: wma9 bearings #202226
    PIP-pm-
    Re: wma9 bearings
    Accetalyne gass cuts the old spider off the bolts a treat just watch the drum :rolls:
    in reply to: wma9 bearings #202219
    PIP-pm-
    Re: wma9 bearings
    I always change the bearings but have work shop facilities and take machine there i also have access to a bearing press which makes life a lot easier i also have a few spare drumms pre assembled so i just change over in workshop then rebuild worn unit when i get quite 10 mins. And yes i always use new tub seal never had a leak yet.
    in reply to: Hoover HW 6316MUK No Spin #202172
    PIP-pm-
    Re: Hoover HW 6316MUK No Spin
    Have you checked presure switch and chamber for blockage
    in reply to: Hotpoint and Servis #201925
    PIP-pm-
    Re: Hotpoint and Servis
    Wouldn’t that be merloni and servis then
    in reply to: hoover twin tub #201851
    PIP-pm-
    Re: hoover twin tub
    I may have one still in stock if it will help send me a pm
    in reply to: Appliance plugs & Warranty #200223
    PIP-pm-
    Re: Appliance plugs & Warranty
    in reply to: WMA40, constant knocking noise #198185
    PIP-pm-
    Re: WMA40, constant knocking noise
    Wouldnt like to comment on how much to quote but these are held on by torques screws (the little star shaped thingys that join the tub together) i have never been able to get one to undo yet i usually cut them out of the arm with oxy acetelyne 😯
    in reply to: Does anyone remember these? #195514
    PIP-pm-
    Re: Does anyone remember these?
    I still have some spares kicking about for the rolls twintub. Also got some bits of the old Hoover sloping front keymatic and the old hotpoint twin with the glass spinlid if anyone goes back that far :rolls:
    in reply to: AEG b4100-1-a oven #193988
    PIP-pm-
    Re: AEG b4100-1-a oven
    Thanks ordered and on it’s way
    in reply to: Creda oven Mod 48902 Ser no. 25100091 #193323
    PIP-pm-
    Re: Creda oven Mod 48902 Ser no. 25100091
    Ive had a simalar problem on a philips oven cut out stat is usually on the top of the oven unit but mine was caused by the small blower fan also on the top had stopped so the controlls got to hot up top and cut out cut out stat
