September 19, 2013 at 6:04 pm in reply to: Zanussi WJD1257W Washer/Dryer fills but won’t wash/spin/dry #401492
Robin_Hood
ParticipantRe: Zanussi WJD1257W Washer/Dryer fills but won’t wash/spin/
Thanks, Martin. Is it a relatively simple job to do (for a novice)?
Robin_Hood
ParticipantRe: Diplomat ADP5520 Range cooker – Main Oven
New clock/timer (from UK Whitegoods store) now fitted and working and main oven is working fine. 😀
Might need to fit some new door hinges for the sake of efficiency though 🙁
Robin_Hood
Thanks again. The clock didn’t tell the time before it went bang! 🙂 The cook in the house (not me) claims a working (again) timer facility will be very useful. Should I replace all the wires that need new connectors or just trim them back (assuming there’s enough ‘slack’)? If so do I need a particular type of wire?
:worthy:
Robin_Hood
Thanks for your guidance. I managed to look at the clock and the power out connection had burnt out taking a couple of the other connectors with it. I have ordered a new clock/timer. What spec are the connectors/insulators likely to be as it look like I will have to replace at least a couple?
ThanksJune 19, 2013 at 7:24 am in reply to: Diplomat ADP5520 – Main oven not functioning – fuses ? #396195Robin_Hood
ParticipantRe: Diplomat ADP5520 – Main oven not functioning – fuses ?
Update: Continuity test indicated that the bottom element was at fault. Replaced it with a new element (from UK Whitegoods) but still no heat, light or fan. The small oven is still working OK.
😕May 1, 2008 at 6:36 pm in reply to: Diplomat ADP5520 cooker-Main oven-Replacing hinge runners #250945Robin_Hood
ParticipantRe: Diplomat ADP5520 cooker-Main oven-Replacing hinge runner
Now that I know the oven still works, does anyone know how to replace the hinge runners for the main oven door? I have the new parts but I am unsure on how to approach fitting them.
Do I need to remove the front or is there a different way of getting at them?
Does anyone have any diagrams that may simplify things?
Thanks in anticipation.
April 30, 2008 at 9:35 pm in reply to: Diplomat ADP5520 cooker-Main oven-Replacing hinge runners #250944Robin_Hood
ParticipantRe: Diplomat ADP5520 Range cooker – Main oven
Thanks – the timer was the first thing I checked as we’ve been caught out by that before. However your reply spurred me on to do further checking and after much fiddling and aligning of the timer and clock (the clock doesn’t actually work) everything is fine now 🙂
