sandy_beech
  • in reply to: Gorenje Fridg Freezer Problem #290682
    sandy_beech
    Re: Gorenje Fridg Freezer Problem
    Thanks JD – I realised it was unlikely to be a DIY job but is it a viable tradesman fix or should I bite the bullet and buy a new one?
    in reply to: Gorenje Fridg Freezer Problem #290680
    sandy_beech
    Yes just the one – it used to run at around 3-4 depending upon temp in kitchen but now at 6 and still not cool enough in fridge but too cold in freezer.
    in reply to: Bosch Precision Washing Machine WFG-2420 #227843
    sandy_beech
    sandy_beech wrote:Cheers guys – sorted. Well the motor is out and the brushes are knackered – one more than the other.
    What is the best way to ensure that the belt tension is correct?
    Fully sorted and operational again.
    Many thanks for the advice – one brush was to 3/16 long. The only place I went wrong was buying the brushes locally (the washing was stacking up) and paid £26-00 for the brushes (ouch).
    in reply to: Bosch Precision Washing Machine WFG-2420 #227842
    sandy_beech
    Re: Bosch Precision Washing Machine WFG-2420
    in reply to: Bosch Precision Washing Machine WFG-2420 #227840
    sandy_beech
    OK thanks for that but now how do I attack the beast?
    I have the machine disconnected from everything but not sure how to get the motor out. Last one I tackled had the motor on top – sooo easy.
    Thanks again
    in reply to: Bosch Precision Washing Machine WFG-2420 #227838
    sandy_beech
    I tried it on rinse and on cold but it looks as if the drum is not turning though it sounds as if the motor is turning slowly. I am going to try it again once the door has unlocked and I can get the washing out.
