Does anyone use this loop tester info required
Home Forums General Trade Forum Does anyone use this loop tester info required
Viewing 15 posts - 61 through 75 (of 89 total)
  • #381175
    DrDill
    Re: Does anyone use this loop tester info required
    And there above is why this should be left to qualified electricians, conflicting statements about which measurement is correct or safe
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #381176
    madangler1
    To a point I agree. I was a sparky for 10 years before moving to appliances , the more you dig into earth loop the deeper the hole goes unless your going to perform a full battery of tests that your not qualified to do you can never be certain
    The simple way forward is to perform a test to ensure the socket is safe and your getting a reasonable reading. After that its down to you IF you inform the customer.
    Your responsibility is with the appliance not the system.
    #381177
    madangler1 wrote:Your responsibility is with the appliance not the system.
    I’m sure you didn’t intend that that statement could be interpreted as ” jobsworths” did you? That we should ignore issues beyond the plug top? Of course not. 🙂
    Wiring issues with hard wired appliances such as ovens, hobs, extractors and most built in washers cannot simply end at the point of connection. Failings must be notified and, in many cases, the appliance isolated until the problem is rectified. You don’t need qualifications do be able to act safely and responsibly just the good sense to advise calling in one who has.
    I’m no doctor but can sure diagnose the onset of a stroke when I see it and advise they seek help rather than walk away. 😉
    #381178
    madangler1
    No my point is legally your responsibility is with the appliance, obviously on BI the rules change and if there is a issue then as you say isolate and inform the customer of the issue.
    #381179
    DrDill
    Sorry martin you are using any thing to justify your opinion. You are not a doctor so you can not diagnose a stroke you can only give your opinion as you are not qualified! That is my point above, unless you are qualified then you have no basis for telling customers that their electrical installation is not safe, what if you do and the customer then calls out a qualified electrician who tells the customer that their is nothing wrong? She ends up with a bill and you have no qualification to argue that the electrician is wrong. My opinion is that you should never tell anyone this stuff unless you have the qualifications to back it up!
    And on this subject i will bet you that 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of engineers on this site dont even check the polarity and earth continuity to the appliance, and i dont see in the news loads of people being electrocuted by their machines.
    Sent from my iPhone
    #381180
    lee8
    shaun67 wrote:
    Can see where you are coming from Lee8 ! but my point is ,if there are guys out there that don’t do a loop test on hard wired appliances and probably not sure how to do one,but are working on the appliance and say they never had any formal training but are in this trade , then it does not hurt to point them in the right direction .
    Kinda, but Brand Engineers don’t loop test hard wired appliances especially if the appliance hasn’t been removed from installation, they use there multi meter to the nearest earth point (wall socket) or if none near they don’t do any and the basic loop test without green lead at a socket near the appliance.
    For Indie’s there is no legal requirement, sure its easy to do on freestanding, but if you change an element on Mrs Smith built in oven and 3 months later she gets several amps of unpleasantness and dies, your still not liable and that expensive piece of kit is useless and a waste of money, why because the test is only good the day and the time you did it.
    shaun67 wrote:
    These guys are not your average cowboys (well i hope not)and were not afraid to own up and learn from others !! Rather than be negative Lee8 ? why not encourage threads like these? After all it is good for the trade and more people will be safer .Maybe one day it will be governed properly and everyone checked to make sure they are doing the correct safety checks etc .
    Show me the figures of deaths that could have been avoided if an Appliance Engineer had done an Earth/Insulation test. :rotfl:
    Whilst I agree basic tests should be carried out, my point which many have missed is that Govt should bring in Regulation that is both accurate to the needs of the industry and effective, which then results in Nationally recognized training and qualifications and that we can then call ourselves qualified.
    I prefer that method to the current system that nobody is qualified (Unless they are sparks) regulated, monitored, trained which then results in people buying kit they neither need or cannot use properly and relying on internet to learn.
    Until then all of us within the White Goods Industry are not competent to do a loop test and give accurate results, all we are required to do is make the client aware of an issue, which usually results in a spark calling out, issuing a correct result and the client ringing the brand for a refund of the call out because some Muppet stated it was dangerous. :rotfl:
    #381181
    lee8
    Martin wrote:
    The numbers of downloads my “how to use a Megger.pdf file and the massive interest the Megger Thread generated was testament to that. Lee8 had plenty to say on that thread too I recall.:wink:
    Proves my point how poor training is. :rotfl:
    Martin wrote:
    Now that is pushing the bounds of possibility just too far! 😯
    Not when every day I’m called to put right the mess so called profesionals leave behind.
    Today I had a 1 wk old Leisure Home call where the engineer had ripped the floor removing the washer, he fitted 2 PCB’s and still could not get rid of the error code, I call find out the error code meant no fill, found the water tap still in the closed position, nobody moved in as it was delivered and the appliance failed the hand over inspection. The Eng (independent part of a well known WP network) was supposed to have 10 yrs plus in the industry, now I wounder how competent his testing is. :rolls:
    #381182
    lee8
    Just one point you all responsible people doing your tests missed, for it to be legal your test equipment has to be not only calibrated yearly it also must conform to certain requirements, certain martindales etc etc will not be accepted in certain situations.
    100 ohmns is the magic number.
    #381183
    lee8
    You’d look like a muppet though if you got it wrong though. :rotfl:
    Conditions with Similar Symptoms as: Stroke
    Description:
    Below is a list of symptoms of this condition and the other conditions that could cause them.
    Aphasia:
    Dementia
    Endocarditis
    Coma:
    Alcoholism
    Diabetes Mellitus
    Hypoglycemia
    Hypothermia
    Measles
    Seizure Disorders
    Dizziness:
    Anxiety
    Fibromyalgia
    Food Allergy
    Food Poisoning
    Heat Exhaustion
    Insect Bites and Stings
    Menopause
    Migraine Headache
    Miscarriage
    Motion Sickness
    Myocardial Infarction
    Temporomandibular Joint Dysfunction
    Transient Ischemic Attacks
    Headache:
    Allergic Rhinitis
    Amenorrhea
    Anaphylaxis
    Anemia
    Bone Cancer
    Brain Cancer
    Chronic Fatigue Syndrome
    Common Cold
    Cough
    Encephalitis, Viral
    Endocarditis
    Fever of Unknown Origin
    Fibromyalgia
    Food Allergy
    Food Poisoning
    Glaucoma
    Heat Exhaustion
    Herpes Simplex Virus
    Histoplasmosis
    HIV and AIDS
    Hypertension
    Hypoglycemia
    Hypoparathyroidism
    Hypothyroidism
    Influenza
    Lyme Disease
    Meningitis
    Menopause
    Menstrual Pain
    Migraine Headache
    Mononucleosis
    Motion Sickness
    Mumps
    Myeloproliferative Disorders
    Otitis Media
    Pharyngitis
    Photodermatitis
    Premenstrual Syndrome
    Radiation Damage
    Seizure Disorders
    Sinus Headache
    Sinusitis
    Sleep Apnea
    Systemic Lupus Erythematosus
    Tension Headache
    Tuberculosis
    Varicella-Zoster Virus
    Headache, severe:
    Lyme Disease
    Hemiparesis:
    Endocarditis
    Mental deficiency:
    Brain Cancer
    Hypoparathyroidism
    Hypothyroidism
    Muscular Dystrophy
    Near-syncope:
    Anxiety
    Brain Cancer
    Food Allergy
    Migraine Headache
    Pulmonary Hypertension
    Neurologic deficits:
    Radiation Damage
    Numbness:
    Carpal Tunnel Syndrome
    Diabetes Mellitus
    Endocarditis
    Food Poisoning
    Frostbite
    Hypoparathyroidism
    Lyme Disease
    Migraine Headache
    Multiple Sclerosis
    Raynaud’s Phenomenon
    Pain:
    Cellulitis
    Frostbite
    Glaucoma
    Multiple Sclerosis
    Nail Disorders
    Photodermatitis
    Tendinitis
    Ulcerative Colitis
    Warts
    Wounds
    Pallor:
    Endocarditis
    Leukemia
    Motion Sickness
    Seizure Disorders
    Syncope
    Paresthesia:
    Fibromyalgia
    Hyperkalemia
    Multiple Sclerosis
    Speech problems:
    Alzheimer’s Disease
    Anaphylaxis
    Atherosclerosis
    Food Poisoning
    Hypoglycemia
    Hypothyroidism
    Thrombosis:
    Crohn’s Disease
    Varicose Veins
    Vision disturbances:
    Amenorrhea
    Atherosclerosis
    Bone Cancer
    Brain Cancer
    Cataracts
    Diabetes Mellitus
    Food Poisoning
    Glaucoma
    Hypertension
    Hypoglycemia
    Migraine Headache
    Multiple Sclerosis
    Preeclampsia
    Roundworms
    Vomiting:
    Alcoholism
    Anaphylaxis
    Angioedema
    Appendicitis
    Brain Cancer
    Cirrhosis
    Congestive Heart Failure
    Crohn’s Disease
    Diabetes Mellitus
    Diverticular Disease
    Encephalitis, Viral
    Food Allergy
    Food Poisoning
    Gallbladder Disease
    Gastritis
    Gastroesophageal Reflux Disease
    Glaucoma
    Heat Exhaustion
    Hepatitis, Viral
    HIV and AIDS
    Hyperparathyroidism
    Hypoparathyroidism
    Influenza
    Intestinal Parasites
    Kidney Stones
    Measles
    Meningitis
    Menstrual Pain
    Migraine Headache
    Motion Sickness
    Pancreatitis
    Pelvic Inflammatory Disease
    Peptic Ulcer
    Peritonitis
    Pertussis
    Pyloric Stenosis
    Radiation Damage
    Roundworms
    Syncope
    Weakness:
    Atherosclerosis
    Bone Cancer
    Cirrhosis
    Colorectal Cancer
    Diabetes Mellitus
    Endocarditis
    Food Poisoning
    Hyperkalemia
    Hypothermia
    Low Back Pain
    Migraine Headache
    Prostate Cancer
    Sarcoidosis
    Serum Sickness
    Read more: http://www.umm.edu/altmed/articles/stro … z295rrzW3C
    #381184
    DrDill
    Exactly lee8, you put it so much better than me.
    Sent from my iPhone
    #381185
    Brains
    I would like to add my two-penny worth. I know that this will start some flack. :rolls:
    100 ohms EFLI is far to high for any final circuit. When you take into account parallel paths created by Main Protective Bonding (even for a TT supply configuration) then one would expect a very much lower value.
    The 100 ohm figure is normally the absolute max value for the external EFLI value at the origin of the supply. If you have measured external EFLI values in the region of 200 ohms then you may have unstable earth rod arrangement for a TT supply.
    The typical EFLI max values you should be looking will be dependent on the controlling fuse or circuit breaker at the Consumer Unit.
    So, why do we measure EFLI? This has not been clearly explained in any of the posts.
    The reason to measure this value is to assure that the protective device (eg fuse or MCB) will clear within a specify period of time (for TN installations below 32A within 0.4 seconds) under fault conditions.
    So for TN type installations,
    16A type B MCB max EFLI is 2.87 ohms
    20A type B MCB max EFLI is 2.30 ohms
    32A type B MCB max EFLI is 1.44 ohms
    40A type B MCB max EFLI is 1.15 ohms
    When carrying out measurements always take 80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the above values as your working max. The 80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} value is a generally recognised rule of thumb (ROT) value that takes into account things as installation and thermal conditions.
    if a 30mA RCD is present, then you will need to use the ‘no-trip’ mode on the loop tester. The absolute max value here is 1667 ohms to earth. This value is determined by the max allowable touch voltage. L-N loop values are as detailed.
    If you find a loop value that exceeds the above, advise your customer to have the installation checked. Better safe than sorry.
    With regard to calibration, an acceptable verification method is to use a known socket, say, at home or the workshop. Record the values once a month and you can then see if the meter is drifting.
    I could ramble on a bit more if so requested. Always pleased to help someone if needed.
    Hope the above helps someone & adds clarity.
    Regards
    #381186
    Brains wrote:So, why do we measure EFLI? This has not been clearly explained in any of the posts.
    Give us a clue here Brains…..WTF is EFLI?
    I tried Google but is comes up Elite Football League of India. :rolls:
    Joking aside all this pi$$ taking of late serves no purpose and like the OP Shaun I too am out of here? 😐
    #381187
    Brains
    EFLI = Earth Fault Loop Impedance
    #381188
    DrDill
    See you later martin, as usual when counter arguments are posted that dont fit in with your opinions you start to be jovial. I personally think my opinions and that of others have helped all to see an all round view of what the original poster first asked about and obviosly expand on it , we all know about the piece of equipment, what it does and weather the rest of us should get one, its a forum!
    Sent from my iPhone
    #381189
    madangler1
    Brains wrote:I would like to add my two-penny worth. I know that this will start some flack. :rolls:
    Regards
    you are quite correct HOWEVER this is from a electricians point of view, these readings are the requirements to prevent death from direct electrocution to human or livestock, however this does not concern appliances,
    on an appliance your concern is that should there be a earth fault the trip will fail with out fire or secondary electrocution from touching the chassis. this is why manufactures train there engineers to accept 100 or 200 ohms.
    the second reason for this is the non trip testers, i spent 10 years performing periodic inspections, non trip is not a valid test as its readings can vary vastly compared to taking a true ZE (external fault loop test at the board) and Zs(internal earth loop) & R1 & R2.
    We can go around in circles all year with this, the simplest way is how the manufactures recommend the tests, regardless of the system with or with out RCD a reading of 200ohm (some say 100) or under is acceptable for an Appliance engineer to deem the system safe for him to work on and allow the appliance to work safely
    anything else is irrelevant
