Indesit IDL500(in the pink)
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit IDL500(in the pink)
Viewing 6 posts - 76 through 81 (of 81 total)
  • #156793
    roly16
    Re: Indesit IDL500(in the pink)
    I wasn’t commenting on the discolouration [everybody else has done that], just on good practice when using a dishwasher. Even though Indesit is at the lower end of the price range a new machine should wash satisfactorily. if you’re getting poor wash results check that the rotating spray arm holes aren’t blocked with food; if they are, take them off and clean them out. the central hub of the arms comes off making it easier to get the bits of food out. Also check that the arms are rotating during wash by noting their position, then shutting the door & letting it wash for a few seconds and checking their position again. They should have moved. If you’re quick enough opening the door you’ll see them stop.
    geoff
    #156794
    Trilobite
    Hello all,
    There is another factor which nobody has mentioned: the detergent.
    The modern powders and tablets use oxygen-based bleaching agents. This can cause a build-up of tannins in teacups and teapots, etc. Tomato sauce can also be difficult to remove.
    The older-style powders, which were more corrosive, used chlorine bleach. This bleaches much more effectively.
    These powders are still available, from Cash&Carry wholesalers, farmers’ supply shops, etc. They are usually marked as “Professional” range; ie, “Finish Professional”, “Sun Professional”, “Bryta Professional”. Look at the ingredients – it should say “chlorine-based bleaching agents
    The downsides are: more expensive (larger pack size); and glassware is more susceptible to corrosion/etching (rainbow patterns, milky-whiteness, scratches, etc).
    #156795
    buddy1471
    Just a quick reply.
    Hotpoint and Indesit are now the same company under the Indesit Company UK Limited name.
    I have a Hotpoint appliance built in Italy which is where the head office of Indesit is based.
    I have also seen discolouration of internal parts of the dishwasher due to Spag Bog dishes being washed.
    However after a few washes the colour can disappear.
    Would recommend the following:-
    Ensure that as much waste sauce is removed by running under the water.
    Wash on high as level of the appliance this is normally 90-95 degrees – This also helps to clean the appliance again which should be run every so often.
    Do not use rinse aide on Hotpoint, Indesit and Ariston (They are also made by Indesit) appliances if using a tablet with rinse aide included. This can cause leaking from the appliance as the appliance thinks that it has not filled to the right level. Also check the leveling of the appliance if this happens. 💡
    #156796
    DDSDDS
    hey folks just caught up on this post dont know if anyone is still reading it but
    just wanna ask one question if it had all been a dull pink inside as new or even pale blue or something would that stop you from buying it?
    but the issues raised here have been very entertaining
    and i can even resurect the car thing
    would you not buy a car cos the dipstick was the wrong colour lol
    how did millymog get on with indesit does anybody know
    still pink refund etc???
    find out in next weeks episode of millymogs pink drawers
    #156797
    millymog
    Im still around…
    The dishwasher wasnt pink or blue or any other colour when i bought it. And yes, its still an off pink.
    I didnt bother pursuing it. Wouldnt have got me anywhere anyway
    #156798
    DDSDDS
