**KNOWN ERROR CODES**
Viewing 15 posts - 46 through 60 (of 151 total)
  • #103893
    Dave_Conway
    Re: Known Error Codes
    LG Dishwasher Error Codes
    IE – Inlet error – 10 minute time out on fill
    OE – drain error – 5 minute time out drain time error
    EI – leak error – water level in tub drops during use
    FE – overfill error – excessive water in tub, drain pump activates
    tE – temperature error – thermistor resistance incorrect
    HE – heating error – no heat (time out) or temperature reaches 95C
    Lucky Goldstar
    #103894
    Codes for most Hotpoint WF, WD, BWD and WT machines without digital display.
    To save my keyboard and avoid RSI these can be read in conjunction with Dave Conway’s post on page 3 of this thread regarding WIDL codes
    The On/Off neon together with a combination of the five left hand option neons will flash if a fault is detected.
    These codes are reading from the top neon down.
    F01….OFF, OFF, OFF, Flash, OFF.
    F02….OFF, OFF, Flash, OFF, OFF.
    F03….OFF, OFF, Flash, Flash, OFF.
    F04….OFF, Flash, OFF, OFF, OFF.
    F05….OFF, Flash, OFF, Flash, OFF.
    F06….OFF, Flash, Flash, OFF, OFF.
    F07….OFF, Flash, Flash, Flash, OFF.
    F08….Flash, OFF, OFF, OFF, OFF.
    F09….Flash, OFF, OFF, Flash, OFF.
    F10….Flash, OFF, Flash, OFF, OFF.
    F11….Flash, OFF, Flash, Flash, OFF.
    F12….Flash, Flash, OFF, OFF, OFF.
    F13….Flash, Flash, OFF, Flash, OFF.
    F14….Flash, Flash, Flash, OFF, OFF.
    F15….Flash, Flash, Flash, Flash, OFF.
    f16….OFF, OFF, OFF, OFF, Flash.
    F17….OFF, OFF, OFF, Flash, Flash.
    F18….OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
    Faults without error codes. If the motor is O/C ( worn brushes ) the machine will not fill or operate.
    The digital display models will generate the actual fault code, ie; F01 etc.
    Additional information, courtesy of johhnyj. A main heater failure will not generate any error codes, the machine will not advance out of the wash cycle.
    Indesit WIDL & Ariston Codes, same as codes for most Hotpoint WF & WD machines without digital display.
    Also Hotpoint BWD, BWM, WF & some WD, left hand lights from top to bottom or digital display.
    widl codes – light flashing from left to right are numbers 1-4
    Also IWM & IWME models.
    f01 light 4, motor triac
    f02 light 3 motor, jammed/ tacho
    f03 lights 3&4 Ntc fault
    f04 light 2. pressure sw stuck on empty
    f05 lights 2&4, pressure sw stuck on full
    f06 lights 2&3, Door Lock does not Open or Close: Check door lock, wiring
    connections at door lock and J004.
    f07 lights 2&3&4 heater relay or O/C element.
    f08 light 1. heater relay
    f09 lights 1&4 eprom/setup error
    f10 lights 1&3, pressure switch not sensing
    f11 lights 1&3&4, pump/draining error
    f12 lights 1&2, communication error
    f13 lights 1&2&4, dryer ntc/ fan motor
    f14 lights 1&2&3, dryer heater
    f15 lights 1&2&3&4, dryer heater relay
    f16 N/A
    f17 light 4, door lock
    f18 light 3 comms error (3 phase motor) power board
    f1 and f17 share the same light
    #103895
    Dave_Conway
    Hoover Late Dishwasher Error Codes
    E1 – no fill
    E2 – temperature control fault (thermistor)
    E3 – water not heating
    E4 – not draining
    E5 – flow meter not reading/counting correctly
    #103896
    Dave_Conway
    Gorenje washing machine error codes with LCD display
    F1: connection to temperature sensor open or shortcircuited.
    The failure is set, if the connection to the
    temperature sensor is open or if there is a short
    circuit between the two terminals of the sensor.
    The washing program will be ended without
    heating.
    F2: The connection with door lock is open.
    The failure is set, if the connection to the door
    lock is open. The washing program stops.
    Supply of door lock will be OFF. The failure
    will be displayed. To continue the washing
    program, the user has to close the door and
    press the „Start“-button. Repeat procedure like
    at START. If the failure occurs again, the
    washing program stops. If the water is in the
    machine, than pumping 2 minutes.
    F3: the water level was not reached.
    – water tap closed
    – leak in the machine
    – valve defect
    The failure is set, if within filling or heating
    step the water level is below level 1 for the
    filling time or 4 minutes in heating time. If the
    failure occurs first time within a washing
    program, the current step starts again. If the
    failure occurs second time (twice in
    succession), the washing program stops, and
    the failure will be displayed. To continue the
    washing program, the user has to press the
    „Start“-button. If the failure occurred third
    time, the washing program stops, the failure
    will be displayed, and it is not possible to start
    the washing program again.
    F4: Inverter can’t control the motor.
    If the washing program is active and the motor
    control unit (Inverter) can’t control the motor,
    then first time the failure occurs a pause of 1
    minutes. This repeat 3 times. If once happens
    that motor works O.K. than all previous failure
    must be deleted. When the failure is detected
    the 4 time’s the washing program stops
    immediately. If the temperature is higher than 60°C than cool down with cold water 30
    seconds. Then pumping water 2 minutes.
    STOP the program.
    F5: No communication between electronic timer and
    Inverter
    If the washing program is active and the motor control unit (Inverter) don’t have communication with main board, then first time
    the failure occurs a pause of 1 minutes. This
    repeat 3 times. If once happens that motors
    work O.K. than all previous failure must be
    deleted. When the failure is detected the 4
    time’s the washing program is stopped
    immediately. If the temperature is higher thaa
    STOP the program. The failure will be
    displayed.
    F6: temperature not reached – heater defect
    The failure is set, if after a heating step the
    temperature is more than 15°C lower than the
    rated temperature. The washing program will
    be ended normally. The failure will be
    displayed at the end of the washing program.
    F7: the water level does not fall below level 1
    – pump clogged
    – pump defect
    The failure is set, if after a pumping step the
    water level did not fall below level 1. If the
    program, the current step will started again. If
    the failure occurs second time (twice in
    succession), the washing program is stopped
    and the failure is displayed. To continue the
    „Start“-button. If the failure occurs third time,
    the washing program is stopped and the failure
    is displayed. It is not possible to start the
    F8: The WM not reach max spin speed (the tapped field relay does not switch)
    The failure is set, if at the end of the spinning
    cycle of the testing program the spin is more
    than 100rpm lower than the rated speed. The
    failure is displayed after the end of the testing
    program.
    F9: Water inside machine (Aqua Stop)
    The failure is set, if Aqua Stop Sensor makes
    signal (must be measuring min. 2 seconds).
    All valves switch OFF, the heater switches
    OFF and main motor STOPS. After 3 seconds
    check again. If the failure is not present, than
    forget the first failure and continue with
    program. If the failure is still present, than
    switch ON the pump for 2 minutes and stop
    WM. The failure is displayed. It is not possible
    to start the washing program again.
    Courtesy of barryfast 🙂
    andy2 wrote:Gorenje washing machine error codes with NO LCD display
    Just to add to Dave’s post, the fault codes are the same for cheaper machines with no display with the exception of:-
    F4 – Tacho open or short circuit (or possibly broken/displaced magnet)
    F5 – Motor triac short circuit (no motor control)
    Codes are signified with all LED’s flashing the required number of times with a 5 sec pause in between.
    Added by gegsy
    #103897
    Dave_Conway
    Late Smeg washing machines and washer dryers, also covers Smeg manufactured rebadged machines
    E1 Water loss safety device
    E2 Anti-spilling device (only outside washing program)
    E4 NTC water in short circuit or interrupted
    E5 No load
    E6 No drain
    E10 Motor overcurrent
    E11 Motor control triac in short circuit or interrupted
    E12 Tachometer
    E13 PTC door block
    E14 NTC dryer in short circuit or interrupted
    E – Interface communication problem – mother board
    E – Card hardware malfunctioning
    #103898
    cab
    LG fault code ce have had broken wire on motor plug
    #103899
    Copied and pasted from a post by allround, thanks for this info. :tup:
    Hotpoint VTD60,CTD80/85/TCD970
    F01 Motor triac in short circuit or
    Relay of motor welded
    closed.
    – Verify if moisture has made a short circuit on connector J3;
    – Verify if the motor connectors on board are ok. (Problems of
    aggressive chemicals can generate a short circuit.)
    – Change the board.
    F02 Blocked motor. (Fan
    blocked)
    – Verify if the motor / fan is blocked;
    – Verify the J3 connectors on the board;
    – Replace motor;
    – Replace fan;
    – Replace main board.
    F03 Front NTC open or short
    circuit.
    – Verify efficiency of the J12 connector on the board;
    – Verify NTC on J12 connector, the value at Room temperature
    of the NTC must be around 500 K?;
    – If the measurement is out of range verify continuity of wiring
    and verify directly on NTC without wiring;
    – Replace NTC;
    F04 No pump connection.,
    feedback.
    – Verify efficiency of contact J5;
    – Verify wiring J5/Pump;
    – Verify pump;
    – Replace pump;
    F05 No feedback from the pump. – Verify contact efficiency of J5 connector of the board;
    – Verify if tension getting at the pump;
    – Verify pump;
    – Replace pump;
    F06 Non used, active –
    F07 Lower element failure
    Check security of module connector J4;
    Test between pins 4 and 3 on J4 (approximately 48 Ohms);
    If open circuit, test lower element and wiring between J4 and
    the heater.
    70802.0000, from this serial number onwards the one shot thermostat is wired into module if this operates the unit will appear dead
    F08 Static heater Relay with NA/
    NC contact welded closed
    – Verify efficiency of contact J4;
    – Verify at room temperature on the J4 connector if the
    resistance between Pin 1 and 2 is 48 ?;
    – Verify continuity between wiring between J4 and Static (lower)
    Heater;
    – Replace Heater;
    F09 Error set up file. EEEPROM
    is not programmed or not
    functioning.
    – If it is a production board with welded EEPROM, replace
    board;
    – If it is a board with removable EEPROM, check the correct
    positioning of the EEPROM.
    F10 Common of heater open,
    one shot open.
    – Verify at room temperature (20°C) on the J4 connector if the
    Heater;
    – Replace Heater;
    F11 No pump connection. – Verify efficiency of board contact J5;
    – Verify wiring between J5 connector and pump.
    – Replace pump;
    – Replace board.
    F12 No communication between
    display board and control
    board.
    – Verify contact efficiency of board connector J9;
    – Verify continuity between J9 and 5 leads connector of the
    display board;
    – Replace main board;
    – Replace display board.
    F13 Rear NTC open or short
    circuit.
    – Verify efficiency of J4 connector on main board;
    – Verify at room temperature (20°C) is about 500K?;
    – Verify continuity of wiring between J4 and NTC rear;
    – Replace NTC;
    F14 Upper element failure.
    F15 Dynamic (PD) heater Relay
    with NA/NC contact welded
    closed.
    – Verify continuity between wiring between J4 and Static Heater;
    – Replace Heater;
    F16 Not used, active –
    F17 Master Relay welded closed – Replace main board
    Edited to include F07. Thanks to lerch & Helo_75
    #103900
    mikehha
    bosch wok 2001 top loader
    Bosch WOK2001 (top loader)
    fault 07 no reading through motor normally motor carbons
    #103901
    gegsy
    You sure about F7, it usually means that the drum is jammed mainly customers leaving the drum door flaps open 🙂
    (some)Bosch Loggixx Dishwasher codes
    Common error codes on models with LED display:-
    A or B = Aqua sensor fault.
    C = No tacho pulses (i.e Motor runs at full speed 2,800rpm).
    D = Short circuit triac to Circulation Pump (pump keeps running).
    E = Water points switching error between top & bottom basket.
    F = Filling error (time out 6 mins)
    G = Water points error, triac fault on circuit board, short circuit.
    H = Heating error (time out) Element, relay on module or pressure s/w.
    K = NTC error
    O = Safety level switching error
    No hard and fast rules apply to the above, but some knowledge is better than none I suppose? 😉
    #103903
    Hoover (Nextra series) washing machines
    The ‘Start’ & ‘Pause’ LED’s will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED’s will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
    1 Flash = Interlock fault
    2 Flashes = Fill time-out
    3 flashes = Drain time-out
    4 flashes = Overfill fault
    5 flashes = NTC error
    6 flashes = faulty control board
    7 flashes = Motor jammed
    8 flashes = Tacho fault
    9 flashes = Motor triac on module board
    10 flashes = Prog Selector or wiring fault
    #103904
    steveDAS
    NECHT DISHWASHER’S WQP12-9319/WQP12-6015/WQP8-9325
    ERROR CODES – WHAT THEY MEAN
    CODE SYMPTOM: CAUSE WHAT TO DO:
    E1 Longer fill time. Faucet is not opened. Ensure that inlet hose is not kinked or crushed.
    E2 Longer or extended draining time. The drain pipe was placed too high when it was installed. Ensure drainage system is as per manual and not extended.
    E3 Longer heating time – not reaching required temperature. Malfunction of temperature sensors or of heating element. CALL for a qualified service technician.
    E4 Overfilled Too much inlet water.
    Note – there are numerous causes of an E4 message. Refer to appliance usage sheet for guidelines on how to prevent an overfill. Overdosing. 3-in-1 put in with salt and/or rinse aid in the appliance = overdose.
    We recommend separate powder and rinse aid to be used not 3-in-1 tablets
    Could also be a water pressure problem.
    E5 Switch can not shut off automatically – program not finishing cycle. Low voltage or power switch failure. CALL for a qualified service technician.
    E6 Open circuit Thermistor. CALL for a qualified service technician.
    E7 Short circuit Thermistor. CALL for a qualified service technician.
    Warning!
    If overflow occurs, turn off the main water supply before calling service technician. If there is water in the base of the tank pan because of an overfill or small leak, the water should be removed before restarting the dishwasher.
    #103905
    electrochris
    Whirlpool sixth sense washers
    this error code is not listed in whirlpool error code list on SIOS disc ( as far as I can see). I have come across this on several different versions of this model.
    door locked light flashing, and machine wont start… “motor open circuit” (usualy carbons)
    #103906
    Dragan
    Whirpool ADG 450/03 Dishwasher
    ALARMS:
    ALARM LED flashing
    E1 L1 The anti-flooding
    system has tripped
    E3 L1+L2 No hetaing the water
    E4 L3 Temperature sensor
    failed
    E5 L1+L3 Unable to fill the water
    E6 L2+L3 Unable to drain
    E7 L1+L2+L3 Turbine flow
    regulator malfunction
    E9 L1+L4 Tank fill limit
    exceeded
    LED L5 is always ON
    L1-the first LED from left ,L2-the second etc.
    #103907
    Candy & Hoover Slimline Dishwashers
    E1 = Filling time-out.
    E2 = Drain time-out.
    E3 = Heating fault.
    E4 = Anti-flood protection.
    E6 = NTC open circuit.
    E7 = NTC closed circuit.
