**KNOWN ERROR CODES**
Viewing 15 posts - 76 through 90 (of 151 total)
  • #103923
    Re: Known Error Codes
    Haier washing machines
    Err 1 – Door is not properly shut 20s after program has started.
    Err 2 – Drainage error, water not emptied within 4 min.
    Err 3 – Temperature sensor is not properly connected or damaged.
    Err 4 – Heater may be broken.
    Err 5 – The required water level is not reached within 8 min.
    Err 6 – Motor speed error, it may be not properly connected or damaged.
    Err 7 – Motor overheat protection or is damaged.
    Err 8 – Water level exceeds protection value.
    Thanks to lerch for this information.
    #103924
    Whirlpool Dishwashers with 2 Digit Display.
    H1/ Eeprom error. This can be temporary.
    H2/ Turbidity sensor error – can be sensor or connections.
    H3/ Water variator valve error – can be valve or connections.
    H4 + H7/ No heat detected in the time allowed. Heater, NTC, connections, relay on PCB, underfilling all possible.
    H5/ Constant fill. Valve failure, T7 triac failure on PCB.
    H6/ No pulses from flow meter. Valve failure, flow meter failure, wiring.
    Overflow. There is no code shown, but drain pump may run constantly. Also, drain pump, flow meter, valve and wiring failures possible.
    Function Test
    Press and hold “Start” and “Programme Select”, switch on. After a few seconds, all LEDs should light briefly. Press “Start” to run test sequence. Any error detected will be displayed as above.
    neptune
    Matsui MWM 145W
    Matsui Washing Machine. This Machine has four lights on the instument panel in a horizontal row. The left one is the start-pause light and the next 3 are options lights. Further to the right are 2 lights in a vertical row. the top one is the program ready light, and the bottom one is the program end light.
    Fault one. start pause light flashing. door not shut.[interlock fault?]
    Fault two.Prog ready flashing. Low water level , heater exposed. Mat be due to low water pressure
    Fault three. Start-pause and prog ready flashing. Pump failure or blocked filter.
    Fault four. not used
    Faultfive. Start pause and prog end flashing. Heater or heat sensor.
    Fault six.Prog ready and prog end flashing motor failure.
    Fault seven start-pause andprog end permanently lit. Configuration error
    Fault eight start-pause and prog end flashing motor failure.
    fault nine. prog ready and prog end flashing. Mains voltage too high[ over260v] Self righting when voltage returns to normal.
    #103926
    Haier Dishwashers with 8 LEDs.
    The four LEDs to the right of the door handle will indicate an error code.
    OXXX – door switch
    OOOX – no fill
    OXOO – no drain
    XOOX – ntc o/c
    OOOO – overflow – flood protection activated.
    Where “O” is lit and “X” is not.
    happycack
    Only got a link to this one but got to be usefull to some of you.
    http://www.appliancepartspros.com/repai … lt{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20Codes
    If you don’t get the link then just ‘cut and paste’
    #103928
    PGS
    Haier HMS1000TVEME fault code E2 =blocked pressure chamber.
    #103929
    don
    Indesit Washing Machine WIXE127UK & V
    FO1 Motor Triac S/C: Check Motor & Module connections
    FO2 Motor jammed/Taco detached: Check Motor & Module connections
    FO3 NTC S/C or O/C: Check Thermistor & Module connections
    FO4 Pressure switch jammed or empty: Check Switch and Module
    FO5 Pressure switch jammed on full or pump blocked: Check Switch and
    Module
    FO6 N/A
    FO7 Heater relay stuck: Check the heater and Module connections
    FO8 Heater relay stuck: Check Pressure switch, heater and Module
    connections
    FO9 Set up Error: Check Eeprom
    F10 Pressure switch not sensing: Check switch and module connections
    F11 Pump cannot be activated: Che ck pump, connections & wiring
    F12 No Communication between cards: Check Module connections
    F13 N/A
    F14 N/A
    F15 N/A
    F16 N/A
    F17 Door lock error: Check door, door lock & module connections
    F18 Communications error (3 phase motor): replace power card.
    WIA autowashers
    Error shown by binary code using the following lamps:
    Spin indicator ——- 1
    Rinse indicator —— 2
    Wash indicator —– 4
    Spin option ———- 8
    Quick wash option – 16
    Add up for fault codes, which are the same as above.
    Edited to add WIA codes. P45.
    #103930
    Hoover 3 phase autowashers.
    1 = D/int or wiring.
    2 = Initial fill exceeded 3.5 minutes.
    3 = Drain not detected in 3 minutes.
    4 = Flood protection activated.
    5 = NTC or wiring.
    6 = Core board or wiring.
    7 = Integrated Circuit Insulated Gate Bipolar Transistor has overheated and a TOC has shut it down.
    8 = Tacho generator out of circuit. Can be wiring or board.
    9 = Integrated Circuit Insulated Gate Bipolar Transistor or motor short or open circuit.
    10 = No listing
    11 = Dryer module or related wiring (Washer dryers only).
    12 = Comms error
    13 = Comms error
    14 = Core board or wiring.
    Hotpoint WML and possibly other recent Indesit clones.
    Read from bottom to top starting with the door lock light as being number 1.
    Uses 5 led’s in all.
    led lit
    …….5…4…3…2…..1
    FO1 off off off off on
    FO2 off off off on off
    FO3 off off off on on
    FO4 off off on off off
    FO5 off off on off on
    FO6 off off on on off
    FO7 off off on on on
    FO8 off on off off off
    FO9 off on off off on
    F10 off on off on off
    F11 off on off on on
    F12 off on on off off
    F17 on off off off on
    f18 on off off on off
    Fault codes same as WIDL codes.
    Thanks to geoff1 for that info.
    EVANO
    BELLING DISHWASHER FAULT CODES
    E1 – If the water inlet valve has worked for 4 mins and the flowmeter detects that not enough water has entered the Dishwasher (3.5l) the the control board will shut down all functions and the alarm buzzer will sound for 30 secs and “E1” will be displayed on the control panel, the Dishwasher will pause for 3 mins and then drain out the water for 90 secs and revert to the rest position.
    E3 – A. If the heating element is still heating after the allowed time, then the control board will advance the programme to next step and at the end of the washing cycle the alarm buzzer will sound for 30 sec and the display will show E3.
    B. When the contol board detects that the heating element is operating during a non heating step or during the internal test the heating circuit is found to be open circuit then the alarm buzzer will sound for 30 sec and the control board will cease all functions except for the drain cycle which will run for 90 seconds and then E3 will be displayed on the contol panel.
    E4 – Any time that the float chamber micro switch operates for more than 2 secs the control board will shut down all functions and operate the drain pump for 30 secs and then sound the alarm buzzer for 30 secs and the control panel displays E4. If the microswitch sets during the draining period then the control board will allow the dishwasher to function normally again , or the dishwasher will then revert to constant draining until the micro switch returns to normal rest position.
    E6 – If after the control board has carried out an internal test and found the thermister open circuit the dishwasher will cease all functions and the alarm buzzer will sound for 30 secs and the control panel will display E6 after a further 3 mins the machine will operate the drain pump for 90 secs and revert to rest position.
    E7 – If after the control board has carried out an internal test and found the thermister short circuit the dishwasher will cease all functions and the alarm buzzer will sound for 30 secs and the control panel will display E7 atfer a further 3 mins the machine will operate the drain pump for 90 secs and revert to the rest position.
    We hope this helps. 😀
    #103933
    neptune
    Amica AWCM 10 L
    from the user manual
    The temperature option lamps form the code
    95 and60 lit door not properly closed
    95 and cold lit low water pressure, check hose tap and hose filter
    95 and 30 lit pump filter clogged
    95 and 40 lit machine overloade. reduce load and check pump filter
    95+60+ cold.no water supply checktap, hose filter etc
    95+60+30 cycle interrupted due to failure to pump out.check pump filter and waste hose.
    #103934
    HEC1050W.
    Sorry about this – Hong Kong Electric Company autowasher. Faults are indicated by the door lock lamp flashing, followed by a 4 second pause before repeating.
    E1 – 0 flashes – Door not locked.
    E2 – 2 flashes – No drain detected in the time allowed.
    E3 – 3 flashes – Temperature sensor fault.
    E4 – 4 flashes – No heat detected in the time allowed.
    E5 – 5 flashes – Time out fill.
    E6 – 6 flashes – PCB fault.
    E7 – 7 flashes – Motor out of circuit.
    E8 – 8 flashes – Fill overflow.
    Candy CMD136-80 Washer-Dryer
    The Active Rinse & 90minute LED’s flash simultaneously, count the flashes for the code :
    1 Flash = Interlock or wiring to it
    2 Flashes = Filling time-out if basic level not reached within 5.5 minutes.
    3 Flashes = Failed to drain after 4 minutes.
    4 Flashes = Anti-flood pressure switch activated.
    5 Flashes = NTC fault or wiring to it.
    6 Flashes = Faulty Coreboard (module) or wiring.
    7 Flashes = Motor or Drum jammed.
    8 Flashes = Tacho fault or motor jammed.
    9 Flashes = Motor triac blown on Coreboard
    10 Flashes = Not used.
    11 Flashes = Faulty dryer module or wiring to it.
    12 Flashes = Communication error between Coreboard and Display Board
    13 Flashes = Communication error between Coreboard and Display Board.
    #103936
    andy2
    GORENJE GV60010 & KGV600 Dishwashers
    If there is a fault for which exist a service diagnostics, it appears as follows:
    1. SOUND SIGNAL – 30 SECONDS
    ERROR ON LED DISPLAY IS BLINKING – 30 SECOND
    DRAIN PUMP IS ACTIVATED
    2. AFTER THE END OF SOUND SIGNAL ERROR ON LED DISPLAY IS LIGHTING
    3. DRAIN PUMP IS STILL ACTIVATED 30 SECONDS AFTER SOUND SIGNAL
    4. AFTER DRAINING ERROR ON LED DISPLAY PERMANENTLY LIGHTING TILL THE
    SWITCHING OFF THE APPLIANCE
    3. TEST PROGRAM
    STARTING TEST PROGRAM
    1. Open the door. Press and hold program button and switch on the appliance. On LED display stands 0A.
    The appliance is ready.
    2. Close the door and test program is activeted
    3. During the test procedure, you can press program button to next step directly.
    4. When test procedure is over, on LED display stands 00.
    E1
    APPLIANCE DOESN’T TAKE WATER
    If pressure switch doesn’t switch on in 4 minutes
    than:
    – Sound signal 30 sek., LED display blinking
    – After sound signal LED display lighting
    – Drain pump drains for 60 seconds
    E2
    APPLIANCE DOESN’T DRAIN WATER
    If drain pump doesn’t drain water in 4 minutes
    (pressure switch doesn’t switch off) than:
    E3
    APPLIANCE DOESN’T HEAT WATER
    If the heater doesn’t heats water in 60 minutes than:
    E4
    AQUASTOP PROTECTION
    If the micro switch of aquastop system is switched
    on for more than 2 minutes, than appliance switch
    off the water inlet and switch on the drain pump:
    E6
    TEMPERATURE SENSOR IN SHORT CIRCUIT
    If the temperature sensor is in short circuit,
    appliance switch off the water inlet and switch on
    the drain pump:
    E7
    TEMPERATURE SENSOR IN OPEN CIRCUIT
    If the temperature sensor is in open circuit (bad
    connection) appliance switch off the water inlet and
    Andy 😀
    #103937
    New World FDW600W Dishwasher
    Wash led flashing: Overfilled
    Wash & Rinse led flashing: Temperature sensor short circuit
    Wash & Rinse & Drying led flashing: Temperature sensor open circuit
    Rinse led flashing: Drain time too long
    Rinse & Drain led flashing: Heating time too long
    Drying led flashing: Water inlet time too long
