margherita 2000 troubleshooting
Home Forums Public Support Forums Help And Support Washing Machine Help Forum margherita 2000 troubleshooting
Viewing 15 posts - 1 through 15 (of 74 total)
  • #8383
    dazz
    Can anyone help me? My Ariston Margherita 2000 ab95 won’t drain or spin. The programming KNOB keeps turning. My girlfriend will kill me when she gets in. cheers
    #128283
    Simon46
    Re: margherita 2000 troubleshooting
    Unplug machine. Lower end of drain/waste hose into a bucket. Let gravity allow the water to run out. Sounds like a coin/hairgrip etc jammed in drain pump impellor. Check in filter (have a towel handy as there will always be some water left in machine). If clear then possibly pump has failed.
    Regards
    Simon
    #128284
    I have the exact same problem! The additional problem I have is that I’ve lost the user manual and now haven’t a clue where the filter is(!) – there’s no obvious door that might open to reveal a filter. Can someone enlighten me before I rip the thing apart searching? Thanks 🙂
    #128285
    Dave_Conway
    Model number please shir, 2000 is a generic range of washing machines.
    #128286
    AWD 12 Advantage… is that it?
    #128287
    Shir wrote:WD 12 Advantage… is that it?
    The pump is behind the bottom plastic kick panel. Simply ease the panel off using a screwdiver on its top edge (no force required). The pump filter cover is accessed by turning anti-clockwise. (Have a few towels ready if the machine is full of water ‘cos it will flood out!!)
    When you have dried up, check the impellor behind the filter is clear and free to rotate. Reassemble in reverse order :tup:
    Job done!
    Thank you all SO MUCH – it fixed my machine! yey! blinkin 5p piece.
    I’d done a trip to the laundrette with one batch of washing (just in case) but thank God it looks like I won’t have to do another (touch wood).
    #128289
    😀 Thank you thank you thank you – my husband and I were panicking – the knob was turning and turnign adn turning and it wouldn’t drain. We followed the instructions from the chap above and hey presto – washing machine is fixed. Whoever you are, you are a star!
    #128290
    thanks for this tip- saved a call to the repairman!
    #128291
    Anonymous wrote:. Whoever you are, you are a star!
    ….he didn’t give his name………just this Silver Bullet!”
    :rotl:
    #128292
    HI,
    I am having a problem with 1.5 year old Margherita 2000 AWD125 Advantage in which knob clicking round and water is not draining out.
    As suggested by you i have cleaned the filter and have got the 50 p coin but the knob is till clicking around and no water idraining.
    Can I request your expert guidance ?
    #128293
    ashday wrote:Can I request your expert guidance ?
    Strikes me that the pump needs closer attention in this case 😉
    i have a problem
    my machiene dont spin any more
    every program its spins
    but for dry spin it do’s nothing
    i check the filter below but i can’t open it
    i can turn it to the right but to open it its stuck
    #128295
    I would suggest then that you call out an engineer in your country to fix it for you 😉
    Ariston AVD149 or Ariston AVG12?
    Can someone help me please? I can’t decide what to buy, Ariston AVD 149 or Ariston AVG 12? 🙄 Is it someone here that knows which of the models is better? I would really appreciate your help. Thankyou 🙂
