Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › margherita 2000 troubleshooting
- This topic has 73 replies, 12 voices, and was last updated 21 years, 1 month ago by
dazz.
March 10, 2005 at 7:37 am #8383
dazz
ParticipantCan anyone help me? My Ariston Margherita 2000 ab95 won’t drain or spin. The programming KNOB keeps turning. My girlfriend will kill me when she gets in. cheers
March 10, 2005 at 7:46 am #128283Simon46
ParticipantRe: margherita 2000 troubleshooting
Unplug machine. Lower end of drain/waste hose into a bucket. Let gravity allow the water to run out. Sounds like a coin/hairgrip etc jammed in drain pump impellor. Check in filter (have a towel handy as there will always be some water left in machine). If clear then possibly pump has failed.
Regards
SimonApril 9, 2005 at 2:26 pm #128284admin
KeymasterRe: margherita 2000 troubleshooting
I have the exact same problem! The additional problem I have is that I’ve lost the user manual and now haven’t a clue where the filter is(!) – there’s no obvious door that might open to reveal a filter. Can someone enlighten me before I rip the thing apart searching? Thanks 🙂
April 9, 2005 at 2:28 pm #128285Dave_Conway
Model number please shir, 2000 is a generic range of washing machines.
April 9, 2005 at 3:03 pm #128286admin
AWD 12 Advantage… is that it?
April 9, 2005 at 3:33 pm #128287Martin
Shir wrote:WD 12 Advantage… is that it?
The pump is behind the bottom plastic kick panel. Simply ease the panel off using a screwdiver on its top edge (no force required). The pump filter cover is accessed by turning anti-clockwise. (Have a few towels ready if the machine is full of water ‘cos it will flood out!!)
When you have dried up, check the impellor behind the filter is clear and free to rotate. Reassemble in reverse order :tup:
Job done!
April 10, 2005 at 5:21 pm #128288admin
Thank you all SO MUCH – it fixed my machine! yey! blinkin 5p piece.
I’d done a trip to the laundrette with one batch of washing (just in case) but thank God it looks like I won’t have to do another (touch wood).
April 12, 2005 at 5:47 pm #128289admin
😀 Thank you thank you thank you – my husband and I were panicking – the knob was turning and turnign adn turning and it wouldn’t drain. We followed the instructions from the chap above and hey presto – washing machine is fixed. Whoever you are, you are a star!
April 14, 2005 at 5:42 pm #128290admin
thanks for this tip- saved a call to the repairman!
April 14, 2005 at 6:43 pm #128291Martin
Anonymous wrote:. Whoever you are, you are a star!
….he didn’t give his name………just this Silver Bullet!”
:rotl:
April 17, 2005 at 1:01 pm #128292admin
HI,
I am having a problem with 1.5 year old Margherita 2000 AWD125 Advantage in which knob clicking round and water is not draining out.
As suggested by you i have cleaned the filter and have got the 50 p coin but the knob is till clicking around and no water idraining.
Can I request your expert guidance ?
April 17, 2005 at 1:55 pm #128293Martin
ashday wrote:Can I request your expert guidance ?
Strikes me that the pump needs closer attention in this case 😉
April 21, 2005 at 6:30 pm #128294admin
i have a problem
my machiene dont spin any more
every program its spinsbut for dry spin it do’s nothing
i check the filter below but i can’t open iti can turn it to the right but to open it its stuck
April 21, 2005 at 6:54 pm #128295Martin
I would suggest then that you call out an engineer in your country to fix it for you 😉
April 22, 2005 at 10:54 am #128296admin
KeymasterAriston AVD149 or Ariston AVG12?
Can someone help me please? I can’t decide what to buy, Ariston AVD 149 or Ariston AVG 12? 🙄 Is it someone here that knows which of the models is better? I would really appreciate your help. Thankyou 🙂
