Whirlpool American Fridge Freezer broken down – help!
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool American Fridge Freezer broken down – help!
Viewing 15 posts - 511 through 525 (of 822 total)
  • #142352
    Shaun1878
    Re: Whirlpool American Fridge Freezer broken down – help!
    Hi again, sorry I haven’t posted back, but something Brodders said, about the flashing display possibly causing problems on the rear board.
    I messed about with the temperature settings, finding one that didn’t cause the flashing on the display.
    Since I did this, the unit has been operating as it should do.
    Although I am of the ‘if it ain’t broke’ mindset, I will change the relays, and the last capacitor on the rear board.
    I am simply enjoying having a product that after so long, is finally operating as it should have done all along.
    Thanks again John,
    Shaun
    #142353
    broddersbaldrick
    Thank you Shaun, you’re welcome. 🙂
    Did you change the caps on the front module?
    brodders
    #142354
    Shaun1878
    Nope, I haven’t changed anything on it since I bought the relays as per your advice.
    All I did was find a setting that stopped the front display from flashing.
    Since then (2 weeks now) all has been well.
    I have started to hear a noise from the freezer, a sort of clunking noise that sounds to me as if the defrost cycle is now working again, and the fridge is maintaining temperature.
    #142355
    silver7
    Hi Guys, Please help!
    Have a whirlpool s20drss33 A/G 8586158120 110445010609 and freezer alarm is going off and showing no temperature. fridge appears ok. Any ideas? all help appreciated!
    #142356
    broddersbaldrick
    Hi Silver7
    In all probability, the components on your rear module have failed.
    Depending on the age of your unit, it will either be the usual capacitor failure or a relay or both.
    Hope this helps
    #142357
    silver7
    thanks very much!
    #142358
    silver7
    Thanks to broddersbaldrick for coming down yesterday and fixing my fridge freezer – much appreciated – good job!
    #142359
    broddersbaldrick
    Ok, today I received the front and rear fridge module that had worked erratically before the replacement of various capacitors.
    I can confirm – fitting the incorrect type of capacitor will kill your modules, if not now then later.
    A dead rear module will cause the front ice maker module relay to click too.
    Fortunately the above modules are in good hands lol 🙂
    Kwatt has put a very handy kit together with instructions for the rear module.
    I fully endorse this kit and point out; it includes an additional capacitor ‘C2’ for installation on boards manufactured with the ‘white’ capacitors. Today I have established it will also replace the 10 volt on later boards.
    Some of you have asked about the Fridge and Freezer temperature sensors especially when the motorised baffle seems to be stuck open or shut.
    For confirmation
    The Freezer temp sensor will measure approximately 23’000 ohms (23k)at -20° degrees.
    The Fridge temp sensor will measure approximately 6’000 ohms at 4° degrees
    These measurements can only be tested with the sensors unplugged from the rear module and the fridge freezer UNPLUGGED from the mains (electricity) supply.
    Hope this helps.
    #142360
    sanfridge
    I would like to say a big thank you to John for all the help and advice in and out of this forum, just got one question in one of the posts you mention that if one wishes to give the defrost relay and ice maker relay a new lease of life, get two 121-8837 relays, there are 3 of these relays in a row which 2 do I need to change.
    #142361
    broddersbaldrick
    from left to right
    Relay 2 = Ice Maker
    Relay 4 = Defrost
    Relay 1 = Standby.
    Hope this helps 🙂
    #142362
    dingle4eva
    Hi I too have one of these crappy whirlpool freezers .I bought it as a graded apliance and after about 18 months there was a power cut and it started defroting flashing and beeping . After reading this forum I bought some capacitors for the rear PCB . It worked for a month then it did the same again I took the PCB back out and replaced it but it aint working . Ive got a bad feeling I have to fork out another ton plus for afront one too . Serial numbers are 858617215000 110607009580 . Could someone please advise ?
    #142363
    broddersbaldrick
    Hi Billy,
    Where did you purchase the rear module?
    There are various levels of software and, the rear module must be the same as the front.
    Is it correct?
    Your fridge freezer may have a fault not associated with the rear module.
    Does the fan next to the compressor run?
    #142364
    dingle4eva
    HI Broddrs bought it here
    #142365
    dingle4eva
    It did need the rear module cos originally it was fixed by replacing the caps . also the new board cured other problems like no water and lettres on digital display . Is it worth mentioning that the old board had small carbon burns on the back ? Oh and the fans working .
    #142366
    broddersbaldrick
    Hi Billy,
    So I have established you have the correct board.
    If the fan is running, the compressor should be running.
    If the compressor is running and you have a freezer alarm, your system may be out of gas or the compressor may be shot.
    Or, you may have a simple defrost ‘heater’ fault
    Does the compressor sound like it’s on?
    It should be warm or even hot to touch.
    There are two pipes on the right side of the compressor; the thin one should be warm / hot.
    The larger one should be cooler.
    We need to establish if the system is freezing the evaporator as it should do.
    If the compressor is not running, report back.
    Hope this helps
