Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › zanussi zwd147s tub seal seems an odd one
- This topic has 195 replies, 18 voices, and was last updated 15 years, 2 months ago by
stryder.
April 18, 2011 at 10:14 am #341508
Applianceman2010
ParticipantRe: zanussi zwd147s tub seal seems an odd one
If the vibration continues check those damper legs the plastic “pin”that holds them in has popped out on me before causing bad vibration. 8)
April 18, 2011 at 11:23 am #341509Martin
stryder wrote:how high should the water level in the condensor be ?
It’s just a trickle of water fed into the condenser from the inlet valve that acts as a cool corridor for the forced air passing through. There is no “water level” but merely the water enters from the top and drains out into the tub at the bottom. I’m suggesting that that ain’t happening in your case. 😉
April 18, 2011 at 3:20 pm #341510stryder
hi
i`ve checked the toc and that seems fine
i`ll just keep plodding on till this is sorted 🙂April 18, 2011 at 3:47 pm #341511Applianceman2010
So what’s it not doing condensing the water?.. its gotta be either the valve or the pcb not giving power to the valve to let in water if that is the case? :hmm:
April 18, 2011 at 4:04 pm #341512Martin
Applianceman2010 wrote:So what’s it not doing condensing the water?..
Take it from me Applianceman2010 that in the public forums it is better to answer questions than to ask them otherwise folks shoot off on a somewhat tangential divergence, serving little or no good overall.:wink:
Stryder’s last comment was with regard to the “TOC” though what the significance of that statement remains as yet unclear with regard to his condenser problems. No doubt all will be revealed in the fullness though….. 8)
April 18, 2011 at 4:30 pm #341513Applianceman2010
Ive gotta be honest i do like asking alot of questions because it means i can give more answers!
The TOC thing was, i think someone posted a reply something like “have you checked the TOC?” and stryer wrote “whats a TOC? give me a clue” and i wrote some clever comment like” maybe thermally operated cut out?” but who ever wrote that then deleted for some reason , so i deleted my comment so i didn’t sound like a mad man with turrets ! whew i need a break after that lol :coffee:April 18, 2011 at 4:54 pm #341514stryder
him again
i put some more washing in and set it as before and would you beleive it- nothing just the sound of the pressure switch clicking. i looked in the condensor, and no water trickling through so i tried several times to set it to dry for 1 hour but it would`nt have it . then for some uknown reason i decided to set it to drain, after it had drained i set it to dry again and this time worked fine . water trickling in and the element heating up and the fan spinning!whats going on? 😕
April 18, 2011 at 6:04 pm #341515Applianceman2010
That’s gotta be a control module fault sounds kinda similar to what mine was doing , loads of random things that didn’t make any sence lol …. good luck! 😉
April 18, 2011 at 6:34 pm #341516stryder
just what i didn`t want to hear 🙁
April 18, 2011 at 6:51 pm #341517Applianceman2010
That’s why mine is sat at the back of my workshop! I mabe wrong though 😀 I’m sure you can find someone on here to egg you on lol
April 18, 2011 at 9:22 pm #341518stryder
i don`t want egging on or any other type of farm food
i just want the f- the darn thing to work properly so i can plumb it in permanently and forget about it!April 18, 2011 at 10:32 pm #341519leavemetogetonwithit
stryder wrote: then for some uknown reason i decided to set it to drain, after it had drained i set it to dry again and this time worked fine .
whats going on? 😕Could be you have a drain pump which is not operating consistently. This could either be due to a partial blockage or possibly something like coin intermittently causing the pump to fail to start. Or it could be a worn pump – remove and examine for play in the impellor bearing. Or that could be a complete red herring! Welcome to the world of washing machine repairs! If you enjoy frustration, this is the job for you!
Mike.April 19, 2011 at 5:18 pm #341520stryder
thanks mate
its a bit like doing one of those rubic cubes 🙂April 20, 2011 at 8:59 pm #341521quickwash
Hi stryder,
Glad to see you back!!
I used to dis-mantle my rubik cube completely and put it back together feeling rather smug 💡
Dont do that with the washer/dryer though!!
Good luck,
quickwash :plug:
April 20, 2011 at 9:06 pm #341522stryder
me too, only i used to take all the stickers off and put them back as though i`d solved it 🙂
