Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › zanussi zwd147s tub seal seems an odd one
- This topic has 195 replies, 18 voices, and was last updated 15 years, 2 months ago by
stryder.
January 21, 2011 at 10:43 pm #341343
stryder
ParticipantRe: zanussi zwd147s tub seal seems an odd one
hello . again. just had a thought -does it matter which way round the new bearings go in? 😕
January 21, 2011 at 10:49 pm #341344bazza500
no
January 22, 2011 at 8:17 am #341345Martin
stryder wrote:hello . again. just had a thought -does it matter which way round the new bearings go in? 😕
Either way but be careful not to put them in upside down. 😉
January 22, 2011 at 9:24 am #341346quickwash
:rotl: ooooh me back 😉
January 22, 2011 at 1:19 pm #341347stryder
looks like i`ll have to get a new spider after all,
is there some sort of felt gasket that goes on the brass bush ahead of the seal? and where does this extra seal/ boot type thing go? does it slide on the shaft after youv`e put the outer bearing in and sit between the bearing and the pulley wheel?
this is getting complicated, my brain urts 😕January 23, 2011 at 9:51 am #341348Martin
stryder wrote:looks like i`ll have to get a new spider after all,
Not cheap but it’s usually a worn spider that causes the bearings to fail in the first place!
stryder wrote:is there some sort of felt gasket that goes on the brass bush ahead of the seal?
No
stryder wrote:and where does this extra seal/ boot type thing go?
In the bin as it’s not needed on your machine.
January 23, 2011 at 6:24 pm #341349stryder
thanks for that martin. if its not needed why do they include it in the kit? what a waste. actualy after thinking about it there may be other machines that this kit fits that do need it.
January 24, 2011 at 2:13 am #341350quickwash
Probably 😉
January 25, 2011 at 8:11 pm #341351stryder
i put some grease in the lip in each side of the housing on the drum half where the new bearings will go, is this right or do they need to go in dry? i mean do i need to get rid of all this grease before installing them. do you think the grease wil make installation easier or more difficult?
January 26, 2011 at 8:19 am #341352Martin
stryder wrote:do you think the grease wil make installation easier or more difficult?
I should think considerably easier, what do you reckon? 😉 🙂
January 26, 2011 at 8:30 am #341353quickwash
:martin:
January 26, 2011 at 2:16 pm #341354helo_75
Participantany chance you might take a leap, and actually complete this repair?
January 26, 2011 at 3:34 pm #341355quickwash
Me thinks, stryder will need a lot of grease soon, cause the whole machine will be rusted up 😉 :snigger: . Just :joker:
good luck with it
quickwash :plug:
January 26, 2011 at 6:03 pm #341356stryder
ha ha very funny 😆
this is the first time i have attempted to change a washer drum bearing and before joining this forum i had absolutely no idea how to go about doing so. i have changed a few car wheel bearings but that was years ago. as for the time i`ve just received the parts . from past experience of this sort of stuff i have found that its not a good idea to just go steaming in. hence the large amount of time and questions .
so there , you sarky gits. 🙂January 26, 2011 at 6:08 pm #341357quickwash
Hi stryder,
Just a bit of ‘good clean fun’ . Sorry i couldnt resist :rolls:
Can a lady be a git? Probably 😆
Good on you for giving it a go :tup:
good luck with the grease 😉
quickwash :plug:
