andy_48
Viewing 15 posts - 1 through 15 (of 15 total)
  • in reply to: AEG 9000 tumble dryer diagnostic mode #493516
    andy_48
    Many thanks
    in reply to: AEG 9000 tumble dryer diagnostic mode #493514
    andy_48
    electrofix wrote:ok E83 comes back as
    Thanks, but what does that mean!?
    in reply to: AEG 9000 tumble dryer diagnostic mode #493512
    andy_48
    This is what I read:
    C01 ALL LIGHTS ON
    C02 ? PUMP 000 (FLASHING)
    C03 DRUM ANTI CLOCKWISE – – –
    C04 COOLING FAN – – –
    C05 DRUM CLOCKWISE 033 OR 034
    C06 ? COMPRESSOR 041 OR 042
    C07 ? 000 (FLASHING) THEN 111
    C08 ? 000 (FLASHING) THEN 111
    C09 ? 000 (FLASHING)
    C10 ? E83
    Can anyone explain any of this, please? If E83 is an error code, I can’t find any mention of it.
    in reply to: AEG 9000 tumble dryer diagnostic mode #493511
    andy_48
    electrofix wrote: in your case its the start and anti crease buttons
    Thanks. The anti-crease button didn’t work but the Start+Refresh buttons did! (I suppose the Refresh button is the nearest).
    Now I’ve got to work out how to interpret the codes!
    in reply to: AEG 9000 tumble dryer diagnostic mode #493508
    andy_48
    Thanks, Dave. I’ll have to wait until the current programme ends or SWMBO will not be happy!
    However, on this model there isn’t really a closest button like on older models. I’ve attached a photo (not a very good one) to seek further guidance.
    in reply to: AEG F65040iM0P Heating Element Location #477677
    andy_48
    Interestingly, I subsequently discovered a small fatberg almost completely blocking (but not quite) the outside drain into which the DW drains the waste water. I’m no expert but I suspect this would also cause the i30 error in the “Drainage problem” category.
    in reply to: AEG F65040iM0P Heating Element Location #477676
    andy_48
    I took it apart and put it back together again and it now seems to be running OK – now with HOT water! Definitely the heating element needed changing and probably the anti-flood sensor not quite sitting properly the first time I reassembled it.
    Anyway, thanks to Dave & Andyjawa for your very valuable help.
    Andy
    in reply to: AEG F65040iM0P Heating Element Location #477675
    andy_48
    Many thanks. I’ll start investigating!
    in reply to: AEG F65040iM0P Heating Element Location #477673
    andy_48
    OK. I changed the heating element and put it back together. Fiddly but seemed successful.
    Now, when I start the dishwasher, the outlet pump does its initial run and when it’s done its bit I get the alarm code “i30 – The anti-flood device is on”. It’s clearly not leaking so I took off the polystyrene float just in case it was sticking but I’m still getting i30.
    What should I look at next, please?
    in reply to: AEG F65040iM0P Heating Element Location #477671
    andy_48
    Brilliant, thanks Dave.
    I’ve got it off and mine does look exactly like that.
    Like a prize idiot I’ve quoted the wrong model number – it should be F65610IM0P – so that is the correct part.
    Thanks again
    in reply to: AEG F65040IM0P ProClean Error code .00 #439981
    andy_48
    Re: AEG F65040IM0P ProClean Error code .00
    This fault has developed slightly (or maybe I just didn’t spot the extra error earlier).
    When first starting the cycle:
    – the pump starts for a few seconds and stops
    – then error .40 flashes for a couple of seconds
    – then error .00 flashes.
    If I turn the DW off and on again, the cycle starts and runs without issue. This is only a minor inconvenience (and is why I haven’t tried to fix it yet).
    I’ve tried changing the socket so I don’t think it’s a voltage issue.
    in reply to: AEG F65040IM0P ProClean Error code .00 #439980
    andy_48
    OK. Many thanks.
    in reply to: AEG F65040IM0P ProClean Error code .00 #439978
    andy_48
    Thanks, Dave
    How can I determine which is more likely?
    in reply to: Cooker hood filters stuck #436684
    andy_48
    Re: Cooker hood filters stuck
    Thanks, Brian. I’ve tried to twist them but they won’t budge.
    in reply to: AEG spray arm alarm but can’t diagnose #383879
    andy_48
    Re: AEG spray arm alarm but can’t diagnose
    No replies – which is not surprising but a bit depressing! I can’t spend my life waiting by the dishwasher every night to open & close the door every time it beeps! If I can’t solve this I’ll have no choice but to buy a new machine.
    One thought – can anyone tell me how to identify and disconnect the spray arm sensor or alarm? That might give the machine a reprieve from the scrapheap!
