dolphin appliance care ltd
  • in reply to: BEKO DSC85W #424213
    Re: BEKO DSC85W
    That’s great, will give those a try!
    Thank you,
    Alister
    in reply to: Engineer vacancies #421031
    Re: Engineer vacancies
    Hi all,
    We have now filled our position in Essex, but we still have vacancies in Kent, East & West Sussex.
    Alister
    in reply to: beko GNEV321APX -HUMIDITY LIGHT ON #421099
    Re: beko GNEV321APX -HUMIDITY LIGHT ON
    Hi Dave,
    Never crossed my mind to do that…. feel a bit daft now…..
    The good news is, its not a fault, it just comes on and off to show the fridge is controlling humidity – its a common question, the young lady reeled off the info immediately!
    And yes, I have the tech info – you were kind enough to send it over on the last Beko SxS
    Many thanks,
    Alister
    in reply to: beko GNEV321APX -HUMIDITY LIGHT ON #421097
    Hi Dave,
    Yes – we have read the book from cover to cover (and back again!). There is no mention of what this means?
    Just FYI its installed indoors in a kitchen, ‘normal’ ambient temperature.
    Thanks,
    Alister
    in reply to: LG WASHER F1443KD #404538
    Re: LG WASHER F1443KD
    A million thanks!
    Alister
    in reply to: SIEMENS WASHING MACHINE FAULT CODE F59 #401770
    Re: SIEMENS WASHING MACHINE FAULT CODE F59
    Any thoughts? cust is getting a bit uptight now :rolls:
    Thanks,
    Alister
    in reply to: Whirlpool/Ignis oven fault codes – F06 #397590
    Re: Whirlpool/Ignis oven fault codes – F06
    Hi Matt,
    We need the model number to be sure (12 digits, starts 85….) but on some pyro models there is an F06 – door lock failure, door locks on self cleaning cycle due to extreme temperatures, if it doesn’t lock it errors out. check door lock or if ok, replace module – but do get the model number if you want to be sure!
    Alister
    in reply to: NEFF S52M69X1GB/16 E24 FAULT CODE #397366
    Re: NEFF S52M69X1GB/16 E24 FAULT CODE
    Thanks Martin,
    will do – thanks for the advice
    Alister
