john_d
ParticipantRe: dishwasher spray arm hitting dishes
hi, the top arm seems to work ok as everything in the top is spotless (looked like a grain of rice in 1 of the holes so i took it out to remove it, bad idea), but neither myself nor my wife have ever moved the tray and had the big plates in the bottom and tall glasses in the top nearly every wash since we got it, i know u guys think im mistaken or dont know what im talking about but i confirmed it with the misses we had both in at the same time. 😕
john_d
Martin wrote:One has to compromise you see. 😉 one or the other but not BOTH! 😀
had it almost a year and i can guarantee 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} that yesterday i was washing dinner plates and tall glasses at the same time, like i have literally dozens of times previously 😉
john_d
iadom wrote:Here’s an idea, how about giving us a make and model first. 😉
Of course you may have slotted the upper basket back into a lower channel or set of wheels.
its a beko DE2542F, i didnt remove the drawer, i just pulled it forward 😐
john_d
but it was fine before, plus i cant then wash my tall glasses 🙁
john_d
ParticipantRe: how long should brushes last?
is that the part the brushes make contact with?
john_d
whats the commuter?
john_d
Hi, its a hotpoint WD71, didnt buy them for where i initally thought, got them from ebay, also got them in nov 2011 so more than a year
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? … 0880322539
guessing they are the cheapest of the cheap 🙁
john_d
ParticipantRe: is this board available to buy?
iadom wrote:Might have been better to keep it to your Original thread 😉
Bear in mind that this part would come to you with no gaurantee and if you fit it without finding out why it blew in the first place then you will almost certainly blow a new one as well.
i was going to add it to the original but it seems to have died a death 🙁
im no further forward to finding out what caused it to go so im resigned to the fact it is likely to go.
john_d
the ful serial no. of the machine or board, where do i find either?
this any use?
john_d
any idea how much, guess around the £100 mark?
john_d
ParticipantRe: hoover ppw166 washer/dryer
ok thanks, ive found either the cause – or a problem caused by the cause.
looking at the board i saw a black sooty mark around some zener diodes so checked the back of the board
so im positive thats why its not working, but what caused this? could an earth leak do this? dont want to buy another board to have the same happen again. 👿
john_d
Martin wrote:
john_d wrote:
dont i need a leak tester?Didn’t I suggest that to you only 2 posts back? 😐
bit confused why they range from £15 up to over £200for the same thing 😯
john_d
Martin wrote:
john_d wrote:
cool, so i need to………………………………….Test the insulation of the components especially the heater and motor. 😉
john_d
Martin wrote:Well I never…..my suspicions are well founded it seems. 😉
cool, so i need to………………………………….john_d
[quote=”Martin”Also it’s worth pointing out that it is important to use a 500volt insulation tester to ensure no spurious earth leakage is causing the PCB to give erroneous messages. We in the trade use them as a matter of course but chances are you do not have such a facility to hand. If you have, then well for you as it may be invaluable. A multimeter is useless for such detective work but at least you can still test those PCB connections with one! 🙂
All the best!
now you mention earth leakage, i should have mentioned this (memory’s not the greatest 😥 ), for about a month maybe 2 the fuse/relay in our electricity mains thingy has tripped when the washers been on, it hasn’t done it often 2-3 times maybe in 2 months, we’re not sure if its the washer but it has always been on when its happened, but so has the fridge etc.
