s_mit
ParticipantRe: Miele WS5425 mc13 user manual and advice needed
t_brenn, I have sent you a pm with my email address, just email me and I’ll send you a copy of the manual.
s_mit
Miele emailed me with PDF manual this morning!
Can I upload directly here for others?(can’t see attach option)s_mit
Thanks for your quick reply!!! 🙂
I have already looked through the list on Miele site but this model is not listed. Don’t know whether its because its a ‘commercial’ machine.
I also emailed them asking if they had a PDF manual i could get…we shall see….to be honest I have more hope from this forum 🙂
January 29, 2009 at 10:24 am in reply to: Hotpoint CTD00 00 squeaks on every drum rotation!! #275344s_mit
ParticipantRe: Hotpoint CTD00 00 squeaks on every drum rotation!!
spoke too soon!!! LOL…..getting noisy again.
seems to be on one direction more than the other.
maybe I will try removing the ‘old’ bearing guide, (6 o’clock). Leaving the 4 that came in the kit (4,5,7 and 8 o’clock).
just remembered….I was left with 1 piece from the kit……my machine didn’t seem to have a place for this object. My best decription of it is : Brass, teardrop with centre hole and hole at top of teardrop. I think this was an alternative rear bearing to my ‘square’ type.
January 29, 2009 at 10:12 am in reply to: Hotpoint CTD00 00 squeaks on every drum rotation!! #275343s_mit
Hey Jim,
my model is ctd 00 p, don’t know if it was an earlier one but yes it has 5 pads.
it seems to be as it gets hotter that vibration occurs.
I think I was pretty thorough with the removal of old seals and cleaning but possiblysome damp fluff got between the felt? I have it on now and seems a bit quieter than an hour ago(only very slight vibration on door now) so fingers crossed.
Thanks again Jim for all your advice and help.
Shaun 🙂
s_mit
I had 5 bearing pads on mine, I used one of the old ‘white’ ones for bottom and 2 new ones to the left and right..
so so i have pads at 4,5,6,7aand 8 o’clock (best way i could decribe it)
btw, new pads were black, old ones white. Dont think this is relevant.
Thanks again
s_mit
Didn’t know whether to start a new thread on this subject so I thought I’d start here, incase anyone else get the same problem.
Okay, so all stripped down, seals/felt replaced, plastic ‘bearings’ (of which I only got 4 new, so used 1 old 1 as well).
Spindle fitted to back of drum, washer behind, then back panel on with square spindle bearing fitted, collar and locking pin.
All done!!! …….but
Now after a couple of mins, after it gets hot, I get vibration, noisy vibration. Sometimes its gets louder then will ‘reverse cycle’ and quiet down a bit.
:rolls: Have I done something wrong?
January 27, 2009 at 10:05 am in reply to: Hotpoint CTD00 00 squeaks on every drum rotation!! #275337s_mit
ParticipantRe: Hotpoint CTD 00 squeaks on every drum rotation!!
Thankyou so much again Guys.
sorry about miss info on model number…..my brain was tired at the time….no excuse!! LOL
hopefully these bit are compatible, they are on order now. 😀
January 26, 2009 at 11:12 pm in reply to: Hotpoint CTD00 00 squeaks on every drum rotation!! #275334s_mit
ParticipantRe: Hotpoint TDC 00 squeaks on every drum rotation!!
Just noticed my model appears to be riveted shaft (2 rivets), not screwed…..
January 26, 2009 at 10:58 pm in reply to: Hotpoint CTD00 00 squeaks on every drum rotation!! #275333s_mit
Thankyou for your quick reply.
You were spot on! Lots of black dust in the cap at the rear!!!
So I’ll asume the kit is what I need.
Anything I should look out for when working out how to dis-assemble and refit? (other than disconnecting the mains…LOL)
Thanks again 😀January 20, 2008 at 8:49 am in reply to: Panasonic NNV629 microwave(Inverter) 10 amp fuse blown #240318s_mit
ParticipantRe: Panasonic NNV629 microwave(Inverter) 10 amp fuse blown
Appreciate your advice…. I am going to buy a new 1 for now until I get a chance to have an enginneer look at it.
Are there any clues in the symptoms I have given which will indicate if this is worth repairing or not?
Thanks for your help once more! 😀
s_mit
ParticipantRe: Delonghi ESM465ST ‘smokes’ when on high temperature
Thanks for your advice, all greatfully received!
One last thing…..do you happen to know of somewhere I can download and instruction manual for this oven….I got one a while ago but lost it and can’t remember where I got it!
Thanks again
Shaun
s_mit
Thanks, I will try and clean oven again with products recomended. Only thing is so far the bottom of the oven seems coated with a layer of hard baked black……something……cleaning so far has not managed to shift!
s_mit
ParticipantRe: Ariston A1535 stuck on program, wont advance,
OK guys, think I have found the problem! After tapping the brushes on the motor the machine started moving again!!!
Guess that means brushes or armature wear.
s_mit
Just moved dial to spin to get 3 very quick flashes then both lights stayed on…….dunno if this adds anything usefull?
