shaun evans
  • in reply to: Hotpoint TDC62 Condenser drier – Erratic heat/drying #300059
    shaun evans
    Re: Hotpoint TDC62 Condenser drier – Erratic heat/drying
    Hello all.
    RESULT !!!
    Did as final_spin and gave the right hand side of the door a few taps and the drying light flickered & sometimes stayed on.
    Top off, turned on and tapped plastic PCB holder gently. Straight away relay began clicking in & out, so power off, saw a couple of possible dry joints on the relays, so re-soldered all the relay connections to make sure.
    Works just fine now, so will keep an eye on it.
    Hope these posts help others.
    Once again many thanks for your help……….Shaun
    in reply to: Hotpoint TDC62 Condenser drier – Erratic heat/drying #300058
    shaun evans
    Thanks for your replies.
    Will have a look around the door stat & relay/PCB areas & see if anything’s amiss.
    Thanks……………Shaun.
    BTW this fault occurs on all heat settings.
    in reply to: Hotpoint TDC62 Condenser drier – Erratic heat/drying #300054
    shaun evans
    Hi iadom,
    When the start button is pressed, the drier always starts rotating, with the “active” light on. The orange “drying light comes on sometimes. If it doesn’t we have to switch off and try again till it does. The orange drying light either stays on momentarily, or goes off in a couple of minutes with little heat being generated.
    Even when the drying light goes out, the drier still keeps on going and going, until it is switched off manually.
    Hopre this helps…………….Shaun.
    in reply to: New Built in oven #233390
    shaun evans
    Re: New Built in oven
    Hi Kwatt & thanks for your fast reply. Any suggestions on which way to go now? Cheers…..Shaun.
    in reply to: Ariston XF905 Built in Maxioven #227990
    shaun evans
    Re: Ariston XF905 Built in Maxioven
    Hi Dave, and thanks for your reply. I think the number you need is…………. 79/22018/00/00. For your additional info the serial number is…..207120076.
    These numbers were taken from the sticker on the rear of the instruction book, and the 79/22018/00/00 number was prefixed by COD.
    Hope this helps……..Shaun Evans.
    in reply to: Ariston LV62 Integrated Dishwasher #204467
    shaun evans
    Re: Ariston LV62 Integrated Dishwasher
    Thanks Penguin, will have a look see & be in touch for spares if need be.
    Regards…………….Shaun.
    in reply to: Ariston LV62 Dishwasher #187009
    shaun evans
    Re: Ariston LV62 Dishwasher
    Hi Dave, thanks for such a quick reply. The model number is as you reckoned, LV621XUK. I’ve had the panel off, and it would appear that the flap is a seperate item (well one that could be removed anyway). It has two “lugs /arms” that fit through two slots, and there is a small circular moulding on the end of each lug /arm that fits into small holes on the backplate, the flap returns by way of a two armed spring.
    Hope this helps, and thanks for your help……..Shaun.
    in reply to: Ariston LV 62 Detergent dispenser fault #161296
    shaun evans
    Re: Ariston LV 62 Detergent dispenser fault
    Hi Penguin 45. Have removed freshener, and all seems Ok now. Many thanks for your help………….Shaun.
