yan_c
ParticipantRe: Neff fridge/freezer (K8614X3GB) behaving erratically
Hi, the symptoms have changed slightly now. Both fridge and freezer only occasionally are getting cold and it sounds like the compressor is trying to start every 2 to 3sec. Maybe a capacitor, but there are two of these so no sure which one? So maybe two unconnected problems as the light is still an issue if the fridge does cool down ie. it stays permanently on, but as soon as the fridge warms up it works fine?
Any help would be most appreciated.
yan_c
Yes that would be too easy. Ive already checked that and its not listed and Ive also called Neff who couldnt help.
I assume there must be two thermostats, one in the main compartment and maybe that one is in the control unit (which Ive just changed) and one in the freezer.
Any other checks I could do?
yan_c
Hi, yes have done that already but it doesnt really help with diagnosing the problem.
Any other ideas?
January 10, 2012 at 9:26 am in reply to: Help Please # Fisher Paykel DD603H – Not draining correctly #366695yan_c
ParticipantRe: Help Please # Fisher Paykel DD603H – Not draining correc
Hi John,
Many thanks for advice. Ok time to take a look inside at the heater then. Any ideas what the two resistance values should be?
I assume it will still be ok to use the top drawer with the bottom removed?
January 8, 2012 at 11:03 pm in reply to: Help Please # Fisher Paykel DD603H – Not draining correctly #366693yan_c
ParticipantFisher Paykel DD603H – hangs during cycle
Hi Many thanks for all the replies.
Ive been doing some more testing and its not displaying errors any longer. Basically it just extends the cycle time by getting stuck for a while in the program before moving on. Eventually it gets to the end and it is pumping the water out aswell. So for example on the fast eco setting the time is 42mins, but after 24mins it hangs for approx 45mins. It then moves on and at 4mins it hangs again for 45mins and then it finishes correctly. I did pause it during each of the “hanged” periods and there was water in the bottom that was quite warm, so maybe the heater is ok and it is the controller after all?
I get the same result with the other settings..
January 7, 2012 at 9:50 pm in reply to: Help Please # Fisher Paykel DD603H – Not draining correctly #366689yan_c
Hi, Are you pretty sure its not the controller? Are there any more tests I can do to be certain of the fault?
If it is the heater plate can you give any advise or point me in the right direction?
September 2, 2011 at 4:53 pm in reply to: AEG lavamat turbo (L 14710-VIT) washer/dryer will not wash? #357812yan_c
ParticipantRe: AEG lavamat turbo (L 14710-VIT) washer/dryer will not wa
Thanks again for all your help on this, I’ll see what I can do…..
Cheers
August 31, 2011 at 11:08 am in reply to: AEG lavamat turbo (L 14710-VIT) washer/dryer will not wash? #357809yan_c
The pnc no. is 914601206/00, hope this helps..
So are there any further checks I can do on the heater unit, just worried it could be the controller board instead?
Also tried running the dryer with the heater unit disconnected and it runs fine (apart from no heat) – strange thought the controller would have detected the heater unit was missing!
Is the heater unit easy to change on this model?
August 27, 2011 at 9:57 am in reply to: AEG lavamat turbo (L 14710-VIT) washer/dryer will not wash? #357807yan_c
Hi, Well disconnecting the heater seems to have sorted it and its running through the wash progs with no problems now. I’ve checked the heater resistance and it measures 103ohms between elements and a very Mohms resistance to earth, so there doesnt seem to be any obvious problem. Are there any other tests I can do with it?
Also is it easy to change and do you know where I could get a new one? Also any ides on cost?
Thanks again for the help.
CheersAugust 26, 2011 at 7:56 pm in reply to: AEG lavamat turbo (L 14710-VIT) washer/dryer will not wash? #357806yan_c
Ok thanks, I’ll give that a go and let you know. As for checking for the error codes, am I doing it right and have you heard of this type of fault before where it just resets afer a couple of mins of a wash cycle?
August 26, 2011 at 2:06 pm in reply to: AEG lavamat turbo (L 14710-VIT) washer/dryer will not wash? #357804yan_c
Hi, Can you tell me how to do this?
Also cant get the error code to appear anymore? I did it initially by holding the start/pause and start/delay buttons together after it had stopped. Doing this now has no effect. The fault is still the same ie. runs for 2/3mins on any wash prog and then stops and prog timer resets as if waiting to be started, but you cant re-start it without doing a reset first. Spin and drain still wk ok.
June 9, 2011 at 11:02 am in reply to: Fisher Paykel DD603H – handel panel replacement advice??? #353266yan_c
ParticipantRe: Fisher Paykel DD603H – handel panel replacement advice??
Hi, Thnaks for the info. Yes its the s/s version just like this:-
http://www.vanns.com/shop/servlet/item/ … /313994787
So are you saying you have to remove the main steel panel that is on the front of the draw so that you get access to the upper plastic panel? And are these screws near the bottom edge as I dont remember seeing any screws on the inside edge on either side? I assume we are talking about the same panel, the one that cover the display and is also the handle?
Cheers
January 24, 2011 at 3:07 pm in reply to: Bosch classixx dishwasher check water light problem – Help!! #340045yan_c
ParticipantRe: Bosch classixx dishwasher check water light problem – He
Replaced the jug impellor and all working fine again, many thanks for the help………..
January 12, 2011 at 12:00 pm in reply to: Bosch classixx dishwasher check water light problem – Help!! #340044yan_c
Many thanks. A new part is noow ordered and I ‘ll let you know how it goes….
January 7, 2011 at 12:34 pm in reply to: Bosch classixx dishwasher check water light problem – Help!! #340042yan_c
Thanks for the replies, most helpful. What is the easiest way to replace the impeller jug as you cant get at it from the lhs? Do you have to lift off the main cabinet or can you get at it from the rear. Also is it possible to test it somehow?
Thanks -
