Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › AEG Oven turning itself off
- This topic has 84 replies, 36 voices, and was last updated 20 years, 12 months ago by
admin.
December 28, 2007 at 5:38 pm #131652
addictivepie
ParticipantRe: AEG Oven turning itself off
philheckler wrote:Picture the scene – xmas day the turkey was in, the kids had opened their presents when to my dismay I noticed the oven had gone off – i was very nervous at this point as we had 6 guests coming for xmas dinner – got it back on again for about twenty minutes when click – off it goes again – at this point i’m hot legging it off to the car with semi a hot turkey (cat in chase!!) to my in laws to cook the bird in their oven…
Anway everything turned out ok in the end and now it’s boxing day – i’ve sobered up and found this thread which seems to be full of the same issues as i’ve got with my Aeg competence – pn 944-181-727 (b1180-1-m) it goes off after about twenty minutes using either the grill or the oven it just cuts out (fan stops / internal light goes out) – please can you recommend the part I need to order to fix this problem (thermal cut out sensor ?) – i’m an electronic engineer so replacing a sensor assembly doesn’t worry me as long as access is relatively simple…
look above for the replies to mine
i have the same pnc to your one
Same problem
fitted new part
just make sure the 2 white wires are around the right way. fitted wtrong in the 1st place and it cut out after 30 minutes
changed the white wires around and it was still on 80 minutes after turning onJanuary 5, 2008 at 1:34 pm #131653Richythesparky
I had the same problem with my AEG competence B4100-1, which seems to be a common occurance with these ovens due to the amount of similar posts I have seen here on this forum.
First of all I would like to say thank you to http://www.ukwhitegoods.co.uk because I ordered the replacement part (cooling fan control part no: 8996619267611) yesterday and received it this morning, now that it what I call fantastic service.
In order to carry out the repairs oneself, I recommend turning off the power first at your fuse box, which should have it’s own circuit. If you are unsure of taking on a task such as this, get a professional engineer to do it for you. Once you get the oven out of the kitchen unit, held by two 1″ phillips screws and the top lid off in two parts held by 4 x 1/4″ phillips screws, replace the cooling fan control sensor by taking off the two blue wires and two white wires one at a time and replacing them one at a time. It may be useful to have some small cable ties handy, to keep the internal wiring tidy, because you will have to cut the old two away anyway. Once the part is in, reassemble the oven to the reverse to what I have just written and job done. You will save yourself £120.00 call out charge that’s if you live in central London.
Good luck. 😀 Tools required for this job are, side cutting pliers to cut cable ties, one standard phillips screw driver, 2-3 small cable ties.February 12, 2008 at 9:13 pm #131654yellowgrid
My oven is doing the same thing. After 20 mins or so the fan and internal lights turn off and it seems to cool down. After a period of cooling the oven then turns on again, lights come on, heat and fan returns.
From reading above I suspect I have the same problem.
My oven details are:
The B2100-4-M
PNC 944185044
Type 91AHB01GACa someone tell me what part I need and tell me whether it is straight forward to fit. I am not an oven engineer but reckon I could fit a part if told how. Many thanks in advance
August 12, 2008 at 5:34 pm #131655chazmolloy
ParticipantRichythesparky, thanks for the tips, you inspired me to do the same repair on my AEG Competence B1180-1-M.
It really was a very simple job, just needed a pair of small pliers to help pull out the old connectors and push the new ones on.
December 23, 2008 at 2:16 pm #131656dasnick
Yes we have the same problem with a B4101-4-M, (PNC 944185051) oven and it drives my wife up the wall. Have ordered the part but am wondering if as the fault seem to be so common could this be a design fault or would getting additonal cooling be a possible answer?
December 24, 2008 at 12:56 am #131657Penguin45
Replacement part is “improved” – allegedly.
January 23, 2009 at 3:34 pm #131658karlosmaximos
i have an aeg oven,not sure of model -about 5yrs old,problem is my tennant says it heats up then cuts out,after so long it will start again,does this sound familiar to anyone?where can i find the model number?
thanks
karlMarch 11, 2009 at 1:03 pm #131659peterd
Have this problem with the oven. PNC 944 181 643
Live in Spain and can you send parts here.If you can please send price and payment method (Have Jersey debit card)
Hoping for your help
Peter
March 11, 2009 at 1:55 pm #131660toby6789
Penguin45 wrote:Replacement part is “improved” – allegedly.
Hi, I have an AEG oven B3101-4M (PN 944185047) but my thermal cut out has only three cables, 2 blue and 1 white. The spare part (8996619267611) on the UKWhitegoods photo seems to have 4 cables. I have pull out the actual piece from the plastic casing and it reads 0 09 70C 9698.
Is this the same part?Thank you
March 11, 2009 at 7:40 pm #131661Penguin45
Yours doesn’t work because one of the white wires has broken away – look again (with the power off). Part listed is correct for your machine.
March 12, 2009 at 9:53 am #131662toby6789
Penguin45 wrote:Yours doesn’t work because one of the white wires has broken away – look again (with the power off). Part listed is correct for your machine.
Thank you very much comrade! I actually had another look last night after reading all the blogs and found the missing cable. I will order the part asap.
You mentioned that the replacement part is “improved” – allegedly. Has anybody check the temperature rating in the new part to see whether is higher, e.g. better thermo resistor?
March 12, 2009 at 9:20 pm #131663Penguin45
Can’t really answer that – I can say that I haven’t had to go back to one which I’ve replaced yet.
April 14, 2009 at 9:57 am #131664NMarshall
My problem with my AEG B4100-1 single oven is that the fan oven does not heat, whereas the setting for top and bottom heat with internal fan does. I checked out cooling fan control part no: 8996619267611 and it was clearly burned out (discoloured casing). Ordered the part from you (fantastic service, by the way) and fitted it this morning – still only unheated air on the fan oven setting. Any ideas?
Neil
April 14, 2009 at 10:21 am #131665Penguin45
ParticipantApril 14, 2009 at 12:19 pm #131666NMarshall
Thanks for the prompt help [and again for the amazingly fast delivery]. Have ordered the element.
Regards
Neil -
