Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › AEG Oven turning itself off
- This topic has 84 replies, 36 voices, and was last updated 20 years, 12 months ago by
admin.
September 2, 2010 at 11:14 am #131682
Millymillward
ParticipantRe: AEG Oven turning itself off
so do i need a ‘fan control thermostat’
if so the link given does not have my oven type listed
mine is a B4100-1-M
PNC – 944181739September 2, 2010 at 11:49 am #131683Martin
Millymillward wrote:if so the link given does not have my oven type listed
But, and you’re gonna have to trust me on this, it’s the very part you need nevertheless. 8)
Mind you in the intervening years since that link was in place by Dave Conway the part number has changed these days from the old ‘AEG number’ reference to the more recent ‘Electrolux’ (Lux) numbering. And so to be fully bang up to date you actually need to order a 3872079029 in fact.:wink:
Just to put your mind at rest why not email spares@ukwhitegoods.co.uk and have a word direct with Mr Dave Conway and all will be revealed.:D
September 27, 2010 at 9:29 am #131684Millymillward
Thank you!
September 28, 2010 at 9:07 pm #131685Nick62
I have the AEG D4100-1M that needs the cooling fan thermostat replaced.
Is 8996619267611 the correct part number for this model?Thanks in Advance
NickOctober 1, 2010 at 11:27 am #131686Nick62
Anyone?
Model no. is D4100-1M and PNC is 944171156
October 1, 2010 at 11:45 am #131687kwatt
KeymasterRe: AEG Oven turning itself off
There are four on that double oven from what I can see, the thermal kit mentioned previously in this thread does not apply to this machine.
There is a thermal cut in and cut out on the roof of the chamber that air is blown through by the cooling fan motor and another two next to the light in each oven cavity on the side.
The 180?C on on the side is this one the other two I’d have to add for you if you need them.
October 5, 2010 at 11:11 am #131688Nick62
Thanks very much.
I can’t get to fixing it for a couple of weeks but I’ll let you know how I get on.
NickNovember 3, 2010 at 8:38 pm #131689Sasq
Earlier in this thread, about 2 years ago, i said the following…
Sasq wrote:Hi Guys,
I have a AEG B1180-1 with the exact same problem. Have verified its the thermal cutout as the fan operates correctly when the part is bridged.
I believe its a 95 degree thermal fuse?Well guess what.. The oven is dead again in a similar way so im sure its the same issue, but i dont recall what test i did to verify. Can anyone help?
SteveFebruary 20, 2012 at 10:07 am #131690barbaracranston
I have read all the previous posts and I have the same problem. Please could you tell me the part number I require for model B2190-1-m PNC 944181735.
Also, what can I check to be absolutley sure this is the problem? I have looked at the top of the oven and nothing is obviously scorched.
Many thanks.
February 20, 2012 at 10:53 am #131691kwatt
The 8996619267611 cooling fan control is certainly fitted to that model.
All you can do to check it is meter everything out and check it but, if the oven is cutting out after a period it’s almost certainly that fan control thermostat that is the problem.
