Ariston Margherita 2000 – I also have a problem!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita 2000 – I also have a problem!
Viewing 15 posts - 46 through 60 (of 252 total)
  • #112810
    davehot
    Re: Ariston Margherita 2000 – I also have a problem!
    ariston will replace the full drum for 90 quid so its not that bad
    #112811
    Why?
    GuinnessMan
    Hi!
    I have tested the Pressure switch according to the instructions in the link in my previous post.
    The pressure switch has 4 connections 3 are labeled 1, 2, 3
    so these are the ones tested as per instructions:
    2 1 3
    No Pressure:
    1 & 2 – Continuity
    1 & 3 – Infinity
    2 & 3 – Infinity
    Pressure:
    1 & 2 – Infinity
    1 & 3 – Continuity
    2 & 3 – Infinity
    So this seems ok.
    As far as I can make out the tube is ok.
    It is almost impossible to get to, to detach from the bottom of the drum
    with out having no bones or turning the machine on its side (is that an ok thing to do??)
    Blew down and seems ok, and Water started coming up the tube when I sucked.
    When I tried the machine again it starts to try and wash when the pressure switch clicks, but then almost immediately stops.
    Where do I go from here?
    Can I adjust the pressure switch?
    I noticed there are adjustments on it.
    Or is it likely to be another problem?
    Cheers
    Guinness Man
    #112813
    GuinnessMan,
    Full marks to you for your persistence on this issue over the Pressure switch albeit I believe you are barking up the wrong tree here 😯
    Unfortunately I suspect the problem is a little more complex, expensive to sort and more likely associated to being a motor problem 😕
    The main Control Module is very sensitive to excess current being drawn by the motor and goes into ‘default’ and ends up with the fault symptoms you describe. It then also gives false error code (flashing light sequence) readings and confusion reigns supreme 😯
    You need an expert to test the motor (500volt insulation test) to confirm my suspicions of course but nevertheless it has to be done. As messing around with the Pressure Switch will only add to further confusion and expense.
    #112814
    kipster
    Machine: Ariston Marherita 2000 AWD12 Advantage
    I’ve had a look through the thread above and think we might have a possible probelm with the pressure switch (though the chap that came out to have a look said not – he took it away and tested it but not sure what he did)
    When selecting a program the cycle will start and the machine will start to fill, the cycle begins but the water continues to come in to the machine and when full is filled and drained continuously throughout the cycle.
    The cycle continues through to completion but throughout takes on water, even through the rince and spin cycle (we have to shut off the water feed so clothes don’t come out wringing wet).
    The machine will drain the water to do the rince but continues to refill at the same time. When it gets to the end of the cycle it the red light flashes continuously but water keeps coming in. If you turn the machine off it stops straight away.
    Any ideas??
    #112815
    Computer board fault, valve not being switched off is a fault in the transistor array.
    If you could post up the full model number we will be able to advise the cost of a replacement board.
    Power off if investigating further……….
    kipster
    many thanks!
    do you know if there is a cause for this that we could do something to avoid occurring in future (if we get a replacement board rather than machine) or if it’s just “one of those things”
    Numbers from the barcode inside the door…
    s/n 312093692 *80260960030
    is this the right info?
    Could you advise on lead times for the replacement.
    Thanks again
    #112817
    jim c
    I Have A Margherita 2000 AWD12 Advantage about 4 years old ,never had any problems ,until now !!
    Light on start button flashes 13 times and program knob keeps spinning.
    Have read all posts relating to model ,tried turning on and off in different sequences,taken filter,tubes and motor off and checked ,no change (apart from 2p found in filter) 🙄
    Any help you can give would be great because ariston quoted £90 call-out and i would prefer to fix it for less . 😉
    I have a manual but i doesn’t help
    jim
    #112818
    jim c wrote:Any help you can give would be great because ariston quoted £90 call-out and i would prefer to fix it for less
    It relates to a dryer heating or overheating problem?
    Either the condenser duct is blocked with fluff or the Dryer Thermistor is open circuit. The former the more likely 😉
    Now I know you want a avoid the £90 call-out Ariston charge, could I therefore venture to suggest you try a local engineer who will be much cheaper (see link below) as it is NOT a DIY fix in any event 🙂
    #112819
    jim c
    Thanks for such a quick reply martin ,but there doesn’t seem to be anyone in my area . 😥
    As i have already had my head under the machine ,where is this condenser duct you mentioned ? as i will have another look . 😉
    jim
    #112820
    Kipster:
    It appears that there are 2 different computers fitted to this one 👿 . One of them runs out at about £85 plus the VAT and P+P, the other one is dearer still. Neither has the EEPROM fitted, so it must be transferred across from the old board. Dave the Spare should be able to identify it properly for you later on. Delivery is usually 5-7 days.
    Jim c:
    Other end mate :D. Heater duct runs across the top of the tank, the condenser duct comes up the back of the tank and mounts under the former.
    Power off if investigating further.
    jim c
    Have stripped heater duct and condenser duct (full of fluff as you said ). 😯
    Heater coil looks burnt out and what i asume is the thermister switch broke into several pieces !! 😕
    Can i get these parts seperate or is it one big lump ?
    If you could give me the part numbers etc i would be very grateful because the wife is giving me grief . 😉
    jim
    #112822
    Dave_Conway
    Kipster, PCB is part number C00093158 at £62.20 plus VAT and carriage, delivery time 3-5 days.
    Jim c, details as follows:
    Heater C00080765 at £16.80
    Thermistor C00080767 at £4.35
    Thermal fuse C00080775 at £9.45
    All plus VAT and carriage.
    An email to spares@ukwhitegoods.co.uk please if any of the above are required 🙂
    #112823
    jim c
    The part that broke was round with 2 spade connectors, 😕 is that the thermister or fuse (it had 2 springs in it !!) 🙄
    How much is carriage and how long will it take ? 😕
    Also i forgot to note the wiring properly does it matter which way the blue wires go on the heating coil ❗ One wire splits and i can’t remember if it goes to one end or the other 😕
    If it needs both parts then thats ok
    thanks jim
    #112824
    Dave_Conway
    The round part is the thermistor, carriage £4.95 and 3-5 working days delivery.
    The wiring I can’t help with I’m afraid (this information won’t be available from Indesit) so you may need an engineer.
