Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › BEKO WDR7543121W Sudden No Power
- This topic has 131 replies, 34 voices, and was last updated 5 years, 9 months ago by
RMC.
March 22, 2021 at 7:50 pm #470359
Moderatorthats the wrong board
thats the display panel and you need the power board
March 22, 2021 at 10:53 pm #470360barruchamps
ParticipantMarch 24, 2021 at 6:21 pm #470361barruchamps
ParticipantOh man… I can’t believe it… It is working!!
https://photos.app.goo.gl/VKBzoBTYaBUKLpEF7
Thanks to all of you guys, I wouldn’t have had a clue without finding this thread and giving it a go.
Love you all 🙂
March 24, 2021 at 6:45 pm #470362electrofix
Moderatorno probs glad you sorted it
this fault is becoming common, had the same fault on a wine fridge today
April 2, 2021 at 3:42 pm #470363PaulMA
ParticipantHello David,
I have the same problem with my washing machine.
I followed all the instructions suggessted and tested the D7 and getting readings one way only.
I tested all others and getting readings as well but the D6 giving readings both ways but the other way only for a short period.
any help will be much appreciated.
pic of the boardand readingsof D7.
https://photos.app.goo.gl/Un57mBdBErA1CDY2AApril 2, 2021 at 5:14 pm #470364electrofix
Moderatorthats a different board and the D6 reading is probably a capacitor charging
have you got a reading across R1 ?
April 2, 2021 at 5:35 pm #470365PaulMA
ParticipantHi David,
thank you for the quick reply.
The R1 reading both ways as in the pictures.April 2, 2021 at 5:56 pm #470366electrofix
Moderatorwhat does the other side of the board look like ?
April 2, 2021 at 8:36 pm #470367PaulMA
ParticipantHi Dave,
Here’s a picture of the other side.
https://photos.app.goo.gl/7oc8aBLPu3GsZh9d7Many thanks
April 2, 2021 at 8:59 pm #470368electrofix
Moderatorwell if it was me i would change U1 and see what happens
please be aware when this board is live there is 300v DC on one of the capacitors
April 3, 2021 at 3:16 pm #470369PaulMA
ParticipantHi Dave,
thank you very much for your suggestion.
This is what’s written on the IC:
LNK564PN
8t035n
I tried to Google it and found the one in this link:https://www.digikey.co.uk/product-detail/en/power-integrations/LNK564PN/596-1039-5-ND/865315
do you think it’s the same?
many thanksApril 3, 2021 at 4:12 pm #470370electrofix
Moderatorlooks right the lnk number is the important on
May 28, 2021 at 10:30 pm #470371Pm71dfc
ParticipantI was wondering if anyone can help me with my issue. My elderly mother has the same washer dryer. Just under 2 years old. 5 months or so ago the machine kept cycling through the spin settings in the display as if the button for spin speed was stuck. I messed around with and seemed to get it working without doing much. It was fine for a while but now it is having problems with powering up. It will work sometimes and other times you need to press the power button several times to get it to go on.
Is this fault likely to be D7 related or potentially the front PCB where the power and spin function buttons are located? Any advice would be welcome.
May 28, 2021 at 11:57 pm #470372electrofix
Moderatorif D7 fails machime would be completly dead
Clean the front panel to make sure its not contamination causing the problem
May 29, 2021 at 9:30 am #470373Pm71dfc
ParticipantThanks Dave I was thinking something like that. Its just when I read on here about D7 issues I wondered if you could get intermittent D7 problems.
